5AT (automatic transmission) Owners With Forced Induction Please Read
Old Mar 15, 2009 | 02:51 AM
  #101
Cass007's Avatar
Cass007
Uhh....{cough..cough}.... Wow, you really blew the dust off this old thread.
Here you go...
Old Mar 15, 2009 | 05:00 AM
  #102
coachk's Avatar
coachk
Originally Posted by fowlman01
Any new info on this problem??????
Valve Body....
/thread
Old Mar 15, 2009 | 08:13 AM
  #103
fowlman01's Avatar
fowlman01
Originally Posted by coachk
Valve Body....
/thread
Valve body didn't work for me and I'm only making 350rwhp.
Old Mar 15, 2009 | 08:14 AM
  #104
fowlman01's Avatar
fowlman01
Here you go...
I appreciate your expert help.
Old Mar 15, 2009 | 08:26 AM
  #105
coachk's Avatar
coachk
Then stop driving like an old man on his way to church
Why didn't it work for you ???
Old Mar 15, 2009 | 08:35 AM
  #106
fowlman01's Avatar
fowlman01
Not sure. It is a Stillen, maybe that is the problem. It is hard to bracket race when you hit the rev limiter with each shift. Shifts slow up and down. It was instant before the Vortech.
  #107
fowlman01's Avatar
fowlman01
I stopped going to church about 50 years ago. lol
Old Mar 15, 2009 | 01:38 PM
  #108
ramairZ's Avatar
ramairZ
I also had the VB upgrade,Import Performance Transmission out of Wayne,NJ, on a '05 w/STS turbo. The trans. always hits the rev limiter. Makes for sloooowwww 1/4 miles.
No new info on this problem?
Old Mar 15, 2009 | 01:55 PM
  #109
coachk's Avatar
coachk
Then raise the rev limiter,problem solved. My 5AT isn't slow in the 1/4
Old Mar 15, 2009 | 02:38 PM
  #110
weslutes's Avatar
weslutes
^^+1
Raise the rev limiter. that fixed it for me
Old Mar 15, 2009 | 02:54 PM
  #111
streetzlegend's Avatar
streetzlegend
How come its hitting the limiter though? was your TCM modified to increase the shift points?
Old Mar 15, 2009 | 02:58 PM
  #112
coachk's Avatar
coachk
With turboed cars the rpms go up very very very fast. Just have to know when to shift.
Old Mar 15, 2009 | 03:25 PM
  #113
streetzlegend
Is it because your tires are spinning making for sudden quick rev's? Iv had a turbo car for a while now and the reason i hit the limiter is because for example in 1st gear, boost comes in quick and tires break loose so it bounces once or twice off the limiter before it shifts, I have adjusted my shift points to be near my limiter which is 6500, which is why it easily touches the limiter.
Old Mar 15, 2009 | 03:42 PM
  #114
d1mon3k's Avatar
d1mon3k
Well, from what I just read, it's adding the VB and raising the Rev limiter to 7200 rpms. I think that really sounds about right. I can raise the limiter with a retune, correct? If so, I'm gonna upgrade my injectors, buy an upgraded valve body and get a retune. I just know that Driving WOT in Auto is scary as hell. Sounds like the **** is f'd up. It's also very hard to shift in Manual mode, because acceleration is so quick from 1-2 gear. It's like I gotta shift at 2500 rpms just to get it to shift b4 redline. WOWeeee
Old Mar 15, 2009 | 04:13 PM
  #115
streetzlegend
I dont think just getting a retune your going to change your shift points on auto. The auto is controlled by the TCM, not the ECU, and I dont know much about the Z community but not alot of companies reprogram TCM's, at least with 5sp. On my 4sp, since it has two solenoids, I use a device called SupraStick, which is design for automatic 4sp supra's but can be used with any two solenoid (4sp) auto. I can control at what rpm to shift at in auto. I dont think they have made one for 5sp auto's since it requires another solenoid, but something to read into for you guys.
Old Mar 15, 2009 | 04:15 PM
  #116
coachk's Avatar
coachk
What type of ems do you have??
Why are you getting bigger injectors?
With a VB upgrade you will be very happy.
Old Mar 15, 2009 | 04:16 PM
  #117
coachk's Avatar
coachk
Correct
Old Mar 15, 2009 | 04:24 PM
  #118
GTM's Avatar
GTM
Vendor - Former Vendor
The Stillen kit isn't a true valve body upgrade, you need to get the Transgo kit.
-George
GT Motorsports
Old Mar 15, 2009 | 05:16 PM
  #119
fowlman01's Avatar
fowlman01
Mine is not all that slow, it is just inconsistent and it will be at least .04sec faster if it shifts the way it did before the vortech.
There are a lot of people that don't think raising the rev limit is a good idea.
I have a 3.55 ear end, so I would still have to shift short.
And I would still have a tranny that didn't shift fast enough.
Old Mar 15, 2009 | 06:15 PM
  #120
streetzlegend
Perhaps the problem is that the added power causes for slower shift (more slip), I am not exacly as far as Z's go, but on auto maximas we do this little mod that we disconnect (while at WOT via a WOT switch), the drop resistor (which controls the fluid pressure in the tranny), by disconnecting it, it provides 100% line pressure therefore almost no slip and almost instant shifts are obtained. Iv had this done for many years as well as others that have been putting alot more power (compared to stock) through the tranny. Like i said, I dont konw if its something you guys would be able to do, just giving an idea.
