5AT (automatic transmission) Owners With Forced Induction Please Read
Old Mar 15, 2009 | 08:14 PM
  #121
fowlman01's Avatar
fowlman01
Originally Posted by streetzlegend
Is it because your tires are spinning making for sudden quick rev's? Iv had a turbo car for a while now and the reason i hit the limiter is because for example in 1st gear, boost comes in quick and tires break loose so it bounces once or twice off the limiter before it shifts, I have adjusted my shift points to be near my limiter which is 6500, which is why it easily touches the limiter.
I run 1.9 6-0 foots so I don't have a lot of wheel spin.
Old Mar 15, 2009 | 08:47 PM
  #122
maXmood's Avatar
maXmood
Under Boost!
would a supercharger like Vortech (non-rev) have the same problem? since they specifically mentioned the "non-rev"?
Old Mar 15, 2009 | 08:53 PM
  #123
fowlman01's Avatar
fowlman01
I have a 2003 with a vortech running 7# boost and it is a huge problem for me.
I may try another kind of VB. I can solve the problem by spending $5-6K, but I would rather not do that. The tranny would shift fast enough before the vortech install to tweak the tires in 2 and 3. Now is takes foreveverrrrrrrrrrrr.
Old Mar 15, 2009 | 09:13 PM
  #124
maXmood's Avatar
maXmood
Under Boost!
i was actually referring to 2006 A/T model that came with the non-rev motors..
how about using the tiptronic? is it slow with that as well?
Old Mar 15, 2009 | 09:17 PM
  #125
mrg1981's Avatar
mrg1981
The VB upgrade and raising the rev limit should fix any problems with this. I used to bounce off the rev limiter, but once it was increase to 8000, that was no longer a problem. I never ran it in auto mode after the rev increase, but I assume it was fixed, b/c I used to have the problem with manual mode and now I don't.
Old Mar 15, 2009 | 09:26 PM
  #126
fowlman01's Avatar
fowlman01
manual mode is worse than auto.
Old Mar 15, 2009 | 09:27 PM
  #127
fowlman01's Avatar
fowlman01
If it shifts fast, I should not have to raise the rev limit.
What VB did you use?
Old Mar 15, 2009 | 09:53 PM
  #128
rcdash's Avatar
rcdash
The gearing is too steep for the 1-2 shift while boosted - loss of traction without exceptional (ie. non-street) tires is the norm and you will bounce the rev limiter no matter how fast the trans shifts. That said, I'm trying R888s soon, so we'll see if that helps in gear 2 at least. I don't have much hope for 1st gear - pedalling is required. I never floor it in 1st gear, nor do I attempt to floor it in auto mode, so ymmv.
MRG I believe has the transgo (or he should if his trans had actually been worked on). I have the same (GTM).
If you're shifts are longer than they used to be, then something is wrong - low line pressure, slipping clutches, or poor grounding (I know some folks don't believe in this, but just connect a heavy gauge wire from your trans casing to negative battery terminal and from there to the ECU ground and see for yourself).
Old Mar 15, 2009 | 10:00 PM
  #129
fowlman01's Avatar
fowlman01
It is worse with DR's on. Do you have the buit GTR tranny with their TC? I pulol 1.9 60's with street tires, so I can't be spinning too much.
Old Mar 16, 2009 | 03:01 AM
  #130
maXmood's Avatar
maXmood
Under Boost!
Fowlman01, i thought you had your issue fixed when you found out it's caused by vortech piggyback??
so, it wasn't the issue with that?
Old Mar 16, 2009 | 07:02 AM
  #131
fowlman01's Avatar
fowlman01
The piggyback was reprogrammed, but it helped very little.
Old Mar 16, 2009 | 11:59 AM
  #132
maXmood's Avatar
maXmood
Under Boost!
^^Considering this, unfortunately and regretfully, i might end up selling the Z.. i'm really disappointed.
i know i won't be able to send my VB for an upgrade, or even can't guarantee shipping one from the States without getting damaged (i can't trust shipping companies anymore).
very sad...
Old Mar 16, 2009 | 12:56 PM
  #133
rcdash's Avatar
rcdash
I have the stage 3 GTM built 5AT. You can check out the shifts in the video I uploaded in my build thread (link in sig). Even when I lost traction, I could shift quickly enough to not hit the rev limiter (7200 rpms), even in 1st gear (though I did lead it in MM mode for the 1-2 shift, not auto - not sure if the 6500 rpm shift in auto would work, but honestly never tried).
Old Mar 16, 2009 | 03:47 PM
  #134
superchargedg's Avatar
superchargedg
Damn Noobs
Get rid of that stillen vb and get one from gtm and you will be fine.The stillen was designed for na or the lame *** stillen s/c.When i went with the greddy twins all i did was bounce off the rev limiter untill i got a FP v/b and it will shift when you tell it too.
Old Mar 16, 2009 | 03:56 PM
  #135
iStan's Avatar
iStan
ZR
Fowlman- I think a new VB and you should be set. With a little less boost than you, I have no problems hitting the rev limiter on my stock trans
Old Mar 16, 2009 | 07:43 PM
  #136
fowlman01's Avatar
fowlman01
How is it for daily driving? and does it downshift quick too??
Old Mar 17, 2009 | 09:39 AM
  #137
black350's Avatar
black350
subscribin
Old Mar 17, 2009 | 03:52 PM
  #138
superchargedg
Damn Noobs
Dailey driving it feels like stock most of the time....but get on the throttle and it shifts hard and fast.I havent really thought about the downshifts or even played with that aspect but i will try it and see if there is a difference.Ill let you know.
Old Mar 20, 2009 | 11:17 AM
  #139
Murfdizzle21's Avatar
Murfdizzle21
so you can't just raise the rev limiter? u guys suggest a vb upgrade too
Old Mar 20, 2009 | 11:21 AM
  #140
iStan's Avatar
iStan
ZR
Raise the Rev Limiter so you don't run into it.
Upgrade the VB so it shifts faster and you don't run into the Rev Limiter.
