Tire FEATHERING: FYI
Old Apr 3, 2003 | 07:28 PM
  #281
goku's Avatar
goku
Default Re: Re: 350Z Track....
Originally posted by ChinaClipper
Yes - my car with over 10000 miles on it is a track. Scroll back a coupel of days on this thread and you will see pictures of my tires.
Damn...between this and the tranny issue, I'm really beginning to think about NOT buying a Silverstone Track
Old Apr 3, 2003 | 07:48 PM
  #282
YourMomma's Avatar
YourMomma
Originally posted by Deb
When you guys post that you have feathering at low mileage, please indicate if you had your alignment checked and adjusted upon delivery or not.
The two dealers had different specs - both claiming to be right; the tire dealer did not have the 350Z specs but called a third dealer and was faxed the same sheet that ChinaClipper posted - it did not say on it which car it included.
[/B]
My alignment has not been checked. I'm going to schedule my service where I plan on getting quite a few things addressed such as:
- Window Grease
- Alignment
- Clutch Noise
- Service Engine Soon (Appeared two nights ago)
The question is what seems to be the best method of addressing the issues. Talking to the dealer first then opening a case with NNA, or opening a case with NNA then going to the dealer.
As to the alignment specs... has anyone with the Service Manual posted the published specs. I'm looking for a scan or screen shot of the page so I can take it to the dealer, vs. an idiot mechanic pulling the incorrect specs.
Old Apr 3, 2003 | 08:55 PM
  #283
aggie300zx's Avatar
aggie300zx
I got one for you...I went to pick up my car today after they replaced my two front tires due to the feathering. Well, from inside the service area I see my car parked out there. A few seconds later I look again and something struck me as odd. I walk out to see my Z rolling backwards down the sloped drive with no one in it. The dumbass mechanic didn't put it in gear and also didn't set the parking break fully. The saving grace was the slope was very short so luckily it did't drift right into a new set of Maxima's. You could only imagine the cussing and commotion I raised. This opened the flood gates as I proceed to rip my service mananger a new one. I will be following up with the service manager in the morning (he was already gone) and then will immediately follow-up with the GM of the dealership after that. This is unacceptable!
I've stayed away from bad mouthing my dealership in the past and I will say my sales experience was great, but NEVER deal with Bankston Nissan of Dallas service department!
Old Apr 3, 2003 | 10:05 PM
  #284
spn350z's Avatar
spn350z
Smile
Today
1) My hearing on lemon laws complainted is scheduled for late May.
2) I got my car back with new front tires. Boy, does that make a difference! Quiet, smooth ride....
3) Bad news is that after the tire swap and alignment my tires were already starting to feather on the inside, 1/32th difference between front and rear of tire tread stub (not side to side) on inside row only.
Nissan North America pays the dealership for only one alignment, my has had three or four and these are a loss for the dealership. So dealership may hessitate.
Service advisor called NNA to inform them of tire feathering after 15/1600 miles, mostly highway miles. They called back and gave him new and different alignment specs! This may be why dealerships show different specs, NNA may be testing out different settings. The following are my specs, in degrees including toe settings (yes, normally toe settings are in inches or mm). My copy of print out shows all settings in degrees!
front left
caster 7.5 to 8.9 before 8.1 after 8.1
camber -1.3 to -0.1 -0.9 -0.9
toe 0.0 to 0.04 0.0 0.05
rear
camber -2.0 to -1.0 -1.6 -1.8
toe 0.02 to 0.05 0.1 0.05
front right
camber -1.3 to -0.1 -1.0 -0.9
toe 0.0 to 0.04 0.1 0.05
rear
camber -2.0 to -1.0 -2.0 -2.1
toe 0.02 to 0.05 -0.05 0.05
total toe front 0.10 rear 0.10
I read somewhere in one post that highway miles may contribute to feathering problem, the current mileage has been on highway 100 and 200 miles at a clip without stopping. I also noticed that at highway speeds the tires bounced (detected the sound of) like going over highway joints but car was not porpoising!
On a side note, one of the old tires required 8 half oz weigths at a single point! This amount followed the tire when it was swapped.
On the lemon law front, Tx DoT MVD does not accept testimony except in person so if I want to show this problem is not an isolated incident I may need bodies to show up. May be with a date set NNA may work on this problem to resolve the problem before the hearing date.
Then may be we will make lemonade! For now I'll enjoy the quiet smooth ride and not mind as much when I have to clean those grease marks.
Old Apr 4, 2003 | 06:06 AM
  #285
aggie300zx's Avatar
aggie300zx
Where in Texas are you? I might be willing to be a warm body. I've had enough of this crap!
Old Apr 4, 2003 | 03:35 PM
  #286
ChinaClipper's Avatar
ChinaClipper
Default alignment specs
The specs I posted in a previous message in this thread ARE from the service manual!
Old Apr 4, 2003 | 07:28 PM
  #287
spn350z's Avatar
spn350z
It is scheduled for Austin on Riverside Drive. I'll keep posting as date gets near.
Thanx
Old Apr 5, 2003 | 02:42 PM
  #288
bozhed's Avatar
bozhed
Just a thought for everyone that is experiencing the tire issues.....if Nissan is not doing anything about this I would think that this would actually result in unsafe conditions for those owners who don't understand feathering. You could report the problem to the Consumer Products Safety Commission (actually it is the Dept.of Transportation)
http://www-odi.nhtsa.dot.gov/ivoq/
On the website
http://www-odi.nhtsa.dot.gov/cars/problems/complain/
you can not only file a complaint, you can search to see if others have reported issues. I did a search and found 4 complaints (5 counting mine). One appeared to have been repeated 2x. So that amounts to 4 total complaints.
If they are going to do something about this, defintely need more people to file complaints.
Old Apr 6, 2003 | 10:58 AM
  #289
dugdi3's Avatar
dugdi3
Default specs on the alignment
I think the problem with the ongoing discussion of the correct toe specs is this: Toe-in should be read in mm or inches. The nominal toe-in spec is .04in PER TIRE for a total toe of .08. Some people on this thread are getting degrees mixed up with the correct measurement of the 350z toe which should be in mm or inches. In addition, if the tech involved in doing your alignment hasn't downloaded the new specs for the Z all measurements on the computer will show in degrees. One of my techs was unable to do the conversion from degrees to inches so I DIDN'T LET HIM TOUCH IT.
I got the specs straight from the dealer who read them off to me.
They were the exact specs Mannishboy posted earlier. BTW, I have feathering on inside and out. The toe alignment is right. I HAVE NO BOUNCING PROBLEM. It could be as simple as these tires
suck. I have checked what comparable cars are using (porshe boxster, infiniti G35) they are using michelin pilot sport tires.
Old Apr 6, 2003 | 11:12 AM
  #290
kawataworks's Avatar
kawataworks
Default Tires Feathering and Cupping is Unsafe!
I further that proposition. Do report your issue to the National Highway Traffic Safty Administration. 1-888-927-4236 or go to www.nhtsa.dot.gov/hotline.
HOW CAN YOUR CALL MAKE A DIFFERENCE?
* The toll-free DOT Auto Safety Hotline is your chance to help identify safety
problems in motor vehicles, tires and automotive equipment such as child
safety seats, or get safety information.
* The Hotline is run by the National Highway Traffic Safety Administration, an
agency of the U.S. Department of Transportation.
* Your call or electronic submissions help lead to recalls.
You provide the first information we use to identify safety problems.
* We review your complaint and compare it to other complaints. If a trend
develops, it prompts us to open an investigation.
* We also let the manufacturer know about your complaint and sometimes
that leads to a settlement for you.
* If a safety-related defect exists in a motor vehicle or item of motor vehicle
equipment, the manufacturer has to fix it at no cost to the owner. We use
the information from your calls and WWW form submissions to get the
process started.
Old Apr 7, 2003 | 05:15 AM
  #291
takes12no1z's Avatar
takes12no1z
Unhappy 2500 miles and feathered
Mine are feather pretty badly and I have mostly Highway miles. I have low speed brake grinding and rubbing sound on sharp low speed turns. I also have the grease streaks on the windows.
I have an appointment to have the car looked at tomorrow at Courtesy in Richardson(Dallas). I will let everyone know all the details as soon as I get them.
I have always been told never to buy the first year of a new car design. I always thought that CAD got rid of this pearl of advice. Oh well. It also sucks that I didn't know Nissan was owned by frenchies until a week after I bought it.
Old Apr 10, 2003 | 08:41 AM
  #292
ChinaClipper
Question What happened at Courtesy?
What was the outcome at the dealer?
Old Apr 10, 2003 | 06:17 PM
  #293
Intrepid's Avatar
Intrepid
This is page 1 of the TSB. The rest of pages simply describe how to properly align and rotate the tires with the pressure sensors.
Attached Thumbnails Tire FEATHERING: FYI-page-1.jpg
Old Apr 10, 2003 | 07:18 PM
  #294
Vincey2kr1's Avatar
Vincey2kr1
If the dealership doesn't entitle free alignments like my dealership (NIssan in Wichita, KS. sucks!) will they have to honor a free alignment under this TSB?? Oh and by the way still stuck with Feathered tires here and still PISSED!.. Nissan North America, still has yet to fix it.
Old Apr 10, 2003 | 07:52 PM
  #295
Boomer's Avatar
Boomer
Make a copy of the TSB, call NNA and then take the TSB to your dealer and don't pay for an alignment, the dealership gets paid for at least one and your feathered tires are part of the TSB. If your dealer balks, call NNA back and they will tell the dealer they'll pay for it. Call NNA every day, several times a day until you talk to a rep, ask for Steve Lam. DO IT!
Old Apr 10, 2003 | 08:06 PM
  #296
YourMomma's Avatar
YourMomma
Default Service
Ok. I'm scheduled to take my vehicle in for service next week. Plan on having them address all these wonderful problems... window grease, clutch noise, early morning clunk, and especially the feathering. I posted this question before, but didn't get an answer....
Should I go to the dealer first with my complaints, or open a case with NNA first? I'm interested in knowing what protocol works better.
PLEASE ADVISE
Thanks!
Old Apr 11, 2003 | 08:47 AM
  #297
kawataworks
Default Re: Service
PLEASE ADVISE
Thanks!
Get a NNA Case number from Steve Lam x3866 or any NNA rep. Steve is the 350Z Specialist and I have been happy with his help.
I am also collecting VIN# & Case #s for those that want to be part of a petition to get Nissan to address and FIX this problem.
So Far I have these people on the list. If you would like to be a part of this petition in order to speed up this process email me at mindfullivin@yahoo.com
Ian - VIN #100157, Case Complaint #4082264
David - VIN #100594
Scott - VIN#100903 Case Complaint #4059755
Robert - VIN#1766
Jason - VIN#100725 Case Complaint #4049797
Vince - VIN#000877 Case Complaint #4075864
Cobey - VIN#101116
Rod - VIN#110836 Case Complaint #4084933
James - VIN#1324 Case Complaint #4079129
Chris - VIN #103197 Case Complaint #4063661
Keith - VIN#0001434 Case Complaint #4023175
Jim - VIN#003283
Steve - VIN#004278
Cam - VIN#103689 Case Complaint #4006573
Steve S. - VIN#006118 Case Complaint #4083945
Tim - VIN#103395
James W. - VIN#101018 Case Complaint #4081081
Brad - VIN#000368 Case Complaint #4069344 (2nd)
Conal - VIN#000786 Case Complaint #4089440
Michael - VIN#010832 Case Complaint #4084381
Matt - VIN#002594 Case Complaint #4089713
Keith G. - VIN#000680 Case Complaint #4088854
The petition will be sent to
Carols Ghosn, President & CEO NML
Shiro Nakamura, Senior vice VP of Design NML
Mamoru Aoki, Chief Product Designer NTC
Kazutoshi Mizuno, Chief Vehicle Engineer NDA
Alfonso Albaisa, Associate Director of Design NDA
Jed Connelly, Senior Vice President NNA,
Bill Kirrane, VP & General Manager, NNA
It will be in both English & Japanese.
Old Apr 11, 2003 | 09:30 PM
  #298
Boomer's Avatar
Boomer
Default Re: Re: Service
David - VIN #100594
Robert - VIN#1766
Cobey - VIN#101116
Jim - VIN#003283
Steve - VIN#004278
Tim - VIN#103395
Perfect! I wonder when Nissan's Japanese Management can take over the company's reins again and Renault can provide TA and get their share of the profits. The push for new models is fierce at the moment and Nissan has a forward plan and the means to implement it. Carlos Ghosn did a lot for the company, but how much longer is he needed?
Old Apr 12, 2003 | 08:19 AM
  #299
rough68fish's Avatar
rough68fish
Default Rumor of fix
Pop posted my laignment readings and car information on iATN (an Automotive technicians network). Someone responded that Nissan HAS a fix, replacement lower control arms.
Can anyone substanciate this?
Old Apr 12, 2003 | 08:23 AM
  #300
cal_z's Avatar
cal_z
Default due process,.....
Well, here is my update. The last phase of tire replacement for me has been complete. But now the car pulls to the right and they cute the rims on both fronts down to the metal. I guess I will be getting a new set of wheels also! Now my next concern is how long does it take to get the tires and rims in after they order them? I would also like to take one of the scratched rims and use it for a spare!! But, will it fit in the spare compartment? Anyway, when they do the tire flip, tell them to be careful not to cute the rim like they did mine! my wheels look like I hit a curb or something. Just be sure to check your wheels before you leave the shop after they flip the tires. Good luck to everyone!!! OH and by the way, The steve guy at NCS seems to be very helpful!
calvin
ss,6mt,touring
P.S. - Will anyone be going to the car show in Lebanon, TN?
