VDC off and slip light are stuck on
Old Aug 18, 2008 | 07:16 AM
350Zsmokinyou's Avatar
350Zsmokinyou
Default VDC off and slip light are stuck on
these two light are stuck on but everything seems to be operating just fine i have no clue what the problem is they just turned on this morning. I did a search a fell up short of any kind of answer need help asap don't even know if i should be driving the car.
Old Aug 18, 2008 | 07:29 AM
OldDirty Z33's Avatar
OldDirty Z33
Can you spin the tires????
Check:
Battery voltage
alternator charge.
all ground connections.
ABS connections/unit possibly doesn't work??
Fuse
reset/check BCM "body control module"
Check for loose connections
Old Aug 20, 2008 | 07:57 PM
fatjoe's Avatar
fatjoe
So what was the problem, because mine just came on today when I was taking off from work.
Old Aug 20, 2008 | 08:05 PM
PikesPeakZ's Avatar
PikesPeakZ
Is the ABS light also on if so you have a brake light issue either a bulb or fuse.
Old Aug 20, 2008 | 08:22 PM
JasonZ-YA's Avatar
JasonZ-YA
turn the car off....then turn it back on...
were you out drifting??
-j
Old Aug 20, 2008 | 08:50 PM
chromesilverz's Avatar
chromesilverz
No other lights and no codes?
You check your tire pressure? Flat tire? if there are no other lights my bet would be brake or tire related as has been pointed out.
Old Aug 20, 2008 | 09:25 PM
Spork's Avatar
Spork
If your rear wheels are spinning and your front wheels turn backwards (losing control, drifting and losing it, etc) it will set it off like that.
Old Aug 20, 2008 | 09:47 PM
JasonZ-YA's Avatar
JasonZ-YA
yup..ive done that at drift days..
Old Aug 21, 2008 | 07:30 AM
350Zsmokinyou
well no drifting was going on and my tire pressure is ok on all fours. i can drive feels normal and when you get it up to about 4k the lights just turn on. but nothing actually happens. but i honestly dont know about the codes where do i get codes from? there is no abs light.
Old Sep 3, 2008 | 05:36 PM
ADMAN's Avatar
ADMAN
You mean, like this???
https://my350z.com/forum/engine-driv...en-before.html
Old Sep 3, 2008 | 06:09 PM
surfcity40's Avatar
surfcity40
check your brake fluid.
Old Sep 3, 2008 | 10:18 PM
ADMAN's Avatar
ADMAN
Nope. Full of MOTUL
Old Sep 4, 2008 | 06:49 AM
bodhicitta7's Avatar
bodhicitta7
Mine did the same thing when the Mass Air Flow Sensor popped off the intake tube. Check the connection there. Good luck.
Old Oct 5, 2008 | 09:50 PM
ADMAN's Avatar
ADMAN
Mine was CPS. Fixed now. Brake fluid still low.
Old Oct 13, 2008 | 09:34 AM
greyson's Avatar
greyson
I had the same thing happen. My "check engine soon" light went on first, then the "vdc off" and "slip" light came on. I kept driving at a track event regardless with no consequences. When my codes were checked, it showed I had a misfire in #5 cylinder. My shop reset the "check engine soon" code and all lights went off and have stayed off so far.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
