FAQ: Official wheel "SPACER" thread!
Old Feb 24, 2011 | 07:19 PM
  #501
tribal_visionz's Avatar
tribal_visionz
I appreciate the quick response! You've reassured all of my questions, if I have anymore you'll definitely see another post. Thanks again, Jason
Old Mar 9, 2011 | 10:07 PM
  #502
350zbehold's Avatar
350zbehold
how long have you guys run 25mm spacer for..cause people said 25mm make ur wheel bearing gone fst
Old Mar 10, 2011 | 01:35 AM
  #503
_ink's Avatar
_ink
Originally Posted by KTran
my drift setup:
18/17x9.5 +15 cs-t zero1
ebay and project kics 30mm spacers all around,
effectively 18/17x9.5 -15
235/35/18 federal ss595rs
245/40/17 " "ss595
What rims are these?
Old Mar 10, 2011 | 03:33 PM
  #504
350zbehold's Avatar
350zbehold
those are mb battle 18x10
Old Mar 10, 2011 | 06:24 PM
  #505
zlatan's Avatar
zlatan
18x9.5 they don't come in 18x10
Old Mar 10, 2011 | 07:46 PM
  #506
350zbehold's Avatar
350zbehold
my mistake...sorry ....can anyone answered my question
Old Mar 10, 2011 | 09:54 PM
  #507
zlatan's Avatar
zlatan
I've run the Ichiba 25mm spacers for 2 years now no issues.
Old Mar 12, 2011 | 06:03 AM
  #508
SponGer's Avatar
SponGer
Me too.
Old Mar 12, 2011 | 10:29 AM
  #509
350zbehold's Avatar
350zbehold
Originally Posted by SponGer
Me too.
is that lowered ? ...if u lowered ...do u have camber kit ?
Old Mar 12, 2011 | 04:56 PM
  #510
zlatan's Avatar
zlatan
My car has been on springs with no camber kit for 2 years. No issues, I bought some BC BR' coilovers that i'll install, I went with a camber kit as well. You should do it right if your going to do it.
Old Mar 16, 2011 | 02:19 PM
  #511
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Default Does a 25mm spacer add camber & require alignment
Does adding a 25mm or 20mm spacer after having had a proper alignment introduce enough additional negative camber (since the wheels are moving out further and slightly changing the angle) to require a new alignment?
I'm changing tires and getting an alignment tomorrow. My current spacers will be too big for the new tires and the stock alignment specs, so I won't be measuring to buy and add new spacers until after I have an alignment done.
Also-
If adding a spacer is going to introduce enough additional negative camber to warrant another alignment, is it reasonable have the mechanic doing the alignment "factor in" the negative camber that will be introduced, or will I have to get another alignment after I add the spacers?
My goals are even tire wear and a nice, flush look.
Thanks in advance.
Old Mar 16, 2011 | 04:28 PM
  #512
350sx23's Avatar
350sx23
...... no to all your questions. ever.
Old Mar 16, 2011 | 04:42 PM
  #513
SparkleCityHop
Living in 350Z
Thanks. I just wasn't sure if pushing the wheels out further would allow the weight of the car to settle slightly lower in the middle, introducing some level of additional negative camber.
Glad to know that I don't have to worry about it.
Old Mar 16, 2011 | 05:02 PM
  #514
terrasmak's Avatar
A 5 to 10mm difference is not going to hurt much. So if your only doing a 5 to 10mm change is spacing, no new alignment will really be needed.
Old Mar 16, 2011 | 05:26 PM
  #515
350Z_Al's Avatar
350Z_Al
It's a wheel spacer..... a 48" wheel spacer wouldn't need an alignment.... That's right, a forty eight inch wheel spacer (four foot wheel spacer) wouldn't need an alignment....
I guess, to sum it up: Wheel spacer DOES NOT affect your alignment, no matter what size it is.
Old Mar 16, 2011 | 08:13 PM
  #516
terrasmak's Avatar
Thats what i thought too, but in reality and the suspension not being in perfect tolerances etc etc it will make a difference. I preached the same thing, but an alignment rack will show different.
Old Mar 16, 2011 | 08:26 PM
  #517
JLS2GOZ's Avatar
JLS2GOZ
Look up Jason Z ya's thread on spaces/lowering.
Old Mar 17, 2011 | 10:30 AM
  #518
350Z_Al's Avatar
350Z_Al
Well then, I guess we all need to get alignments after we change our wheels to wheels that have different widths or offsets since a wheel with more negative offset affects the suspension in the same way that a spacer would........................................
[Everybody else please ignore this post as it has no real world relevance. You do not need an alignment after changing your wheels]
Old Mar 17, 2011 | 06:04 PM
  #519
SparkleCityHop
Living in 350Z
I did and read every page. There was nothing specifically mentioning this.
Old Mar 17, 2011 | 06:07 PM
  #520
terrasmak's Avatar
Technically yes, but all my wheels are set up within 5mm of each other. Theory is one thing ( i agree in the theory) but reality shows something different.
