FAQ: Official wheel "SPACER" thread!
Old Jun 4, 2011 | 09:51 PM
  #541
SnaggleToof's Avatar
SnaggleToof
Hey guys...
Sorry to be a pain in the ***... but i dont feel like reading this whole thread.
I'm wondering what size spacers i should get for my Z. I've got the 03 track package with the trrack wheels on and want a more aggressive look... stock height...
What size spacers do you recommend on my stock setup?
Will be lowering and getting some staggered wheels eventually... saving for my house down payment first though.
Old Jun 4, 2011 | 10:06 PM
  #542
midz350's Avatar
midz350
25/30mm spacers would look the best, but will rub if you lower your car.
Old Jun 4, 2011 | 10:26 PM
  #543
SnaggleToof
Would I be ok to run 25/30mm without having to change anything else? Will it throw out alignment etc?
I only plan on lowering about 1".
Is a 1" drop hard on the stock shocks? An will I need camber kits for 1"? And will 25/30mm rub with 1" drop?
I know I should be trying this stuff on my own, but a little information always helps.
Old Jun 10, 2011 | 10:54 PM
  #544
Anh's Avatar
Anh
Originally Posted by SparkleCityHop
Sorry, been traveling for work. Should get a chance to tackle it in the next week or two when I go back to add the new toe bolts.
Did you get any results? I'm interested in this topic as well haha.
Old Jun 19, 2011 | 09:58 PM
  #545
miles85916's Avatar
miles85916
Mine rubs with 20mm/25mm, but i am lowered 1.8 front and 1.1 rear.
wheel spec
235/40/18x9
255/35/19x10
Old Jun 20, 2011 | 12:43 PM
  #546
Brogan07's Avatar
Brogan07
Newbie question. Do the stock 18' wheels for my 07 have the necessary gaps for the Ichiba Version II (Stud Included) 25mm Wheel Spacers? Is this all I would have to purchase to install?
Old Jun 20, 2011 | 01:08 PM
  #547
ulace's Avatar
ulace
Short answer....Yes.
Old Jun 20, 2011 | 03:34 PM
  #548
Brogan07's Avatar
Brogan07
ty very much!
Old Jun 28, 2011 | 07:40 AM
  #549
crtan77's Avatar
crtan77
Hello,
Okay I tried to read the entire thread but i could have missed it. So if i did i apologize if its been mentioned.
Is anyone running Work VS-XX?
I need to clear my stoptechs and I measured that I need at least 21mm to do so.
19 x 8.5 + 29 255/35
19 x 9.5 + 29 285/35
Does anyone know if i will rub if i buy 25mm spacers all around? I'm lowered on Tein S-Techs.
Thanks in advance...
Old Jul 1, 2011 | 03:52 PM
  #550
omsin523's Avatar
omsin523
Got my Ichiba v2's 20mm in today and noticed one of the rings has a lot of play. While the other spacer is set firm with no play.
Old Jul 7, 2011 | 08:42 AM
  #551
1LightBrick's Avatar
1LightBrick
im gonna do all the ,easurements tonight. but i figure if theres some know-how before i get home that would be nice.
*I did read the thread* ...jjust looking to see if anybodyt has any experience with my specifics..
Want rear spacers going hubcentric and all that, only question is the size.
I'm going to lower the car 1"
I am running stock '03 17s with 255/45/17 and they buldge a bit, obviously.
Have read around that 10-15mm would be max while other people claim 20-25mm would be totally fine...
Old Jul 7, 2011 | 01:01 PM
  #552
Brogan07's Avatar
Brogan07
Here's the difference the Ichiba 25mms made, front and back:
Pre spacers (stock 18"s on 225/45f & 245/45r):
spacers on:
Old Jul 9, 2011 | 10:54 PM
  #553
cphan6778's Avatar
cphan6778
I'm thinking of getting some 19' rims but I think the offset might be too high and from what I can understand the higher the offset the more it's tucked in, I was thinking of getting some spacer so my question is will that decrease the offset? Explain 19x8.0 /w offset of 42 using a spacer of 15mm-20mm would make it like a 19x8.0 /w offer of 22-27?
Old Jul 11, 2011 | 04:09 AM
  #554
350Zenophile's Avatar
350Zenophile
^ You are correct...but even with the spacer those are pretty weak offsets if you are going for a flush look.
Old Jul 11, 2011 | 08:57 AM
  #555
Brogan07's Avatar
Brogan07
Yup, I have 25mm spacers on my stock wheels, which are 30 and 33 offsets, so in effect my offsets are 5mm and 8mm.
Old Jul 11, 2011 | 09:29 PM
  #556
miles85916's Avatar
miles85916
Default spacers 20mm and 25mm
Here is mine
235/40/18 18x9 +30
255/35/19 19x10 +30
Running 20mm Front and 25mm Rear So now its sitting on +10 and +5
Front is drop about 1.8 and the rear is 1.1
No rubs after i got my fender rolled
Old Jul 12, 2011 | 05:17 AM
  #557
Brogan07's Avatar
Brogan07
I once had a Maxima lowered with 20's w/275's in the back and had rubbing nightmares, so I'm pretty happy to stay @ stock height n tires with the spacers giving me the flush look.
For now...
Old Jul 13, 2011 | 06:51 AM
  #558
350ZPK's Avatar
350ZPK
Default Project Kics 10mm spacer and Volk GTS
FOr those about to order some kics and have GTS wheels, the OEM studs hit the wheel so the wheel doesn't sit flush on the spacer.
If you ran a 15mm, i dont see a problem.
Just giving people heads up, for what it's worth
Old Jul 13, 2011 | 07:43 AM
  #559
OkashiZ's Avatar
OkashiZ
thank you! i had a feeling this would happened so i decided not to buy 10mm and hold out until i could find more info. this was the more info.
Old Jul 13, 2011 | 08:06 AM
  #560
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Shorter studs is always an option, for those people that really want to run this combo.
