FAQ: Official wheel "SPACER" thread!
Old Dec 22, 2011 | 06:31 PM
  #681
Diesel350's Avatar
Diesel350
Are all the spacers that the vnedors sell here all pretty much the same? I see prices ranging from $88 to $147
Old Dec 27, 2011 | 11:20 PM
  #682
porsche965's Avatar
porsche965
Default Ichiba V2
Just installed 20mm in the front and 25mm in the rear.
Here is Pre-install pictures:
<a href="http://imgur.com/hTP2E"><img src="https://i.imgur.com/hTP2El.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/7t02c"><img src="https://i.imgur.com/7t02cl.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/yK5Kr"><img src="https://i.imgur.com/yK5Krl.jpg" title="Hosted by imgur.com" alt="" /></a>
And post:
<a href="http://imgur.com/UPyMr"><img src="https://i.imgur.com/UPyMrl.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/NDHRL"><img src="https://i.imgur.com/NDHRLl.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/x9q7N"><img src="https://i.imgur.com/x9q7Nl.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/LBbQ8"><img src="https://i.imgur.com/LBbQ8l.jpg" title="Hosted by imgur.com" alt="" /></a>
The stance is so much more aggressive now and i think it looks great IMHO. The pictures do not do it justice, you have to see it in person for the full affect.
Old Dec 28, 2011 | 01:12 AM
  #683
Brogan07's Avatar
Brogan07
Looks great bro, an I know exactly what you mean with the stance. I have no idea why it's not like that stock.
Now if you lower it, let us know if you get any rubbing.
Old Dec 28, 2011 | 01:03 PM
  #684
porsche965's Avatar
porsche965
Thanks man! Yeah, once it was all finished I was thinking the same thing that stock should be exactly like that. It just transformed the car.
That is definitely in the future and I will post up with any rubbing issues. I will probably go with a smaller drop like tein just to stay on the safe side.
Old Dec 31, 2011 | 07:17 PM
  #685
1991ls13's Avatar
1991ls13
hey guys quick question, Im sure its somewhere in this forum but im a lil confused still after reading the OP. But with these " http://compare.ebay.com/like/1707125..._lwgsi=y&cbt=y "
they dont have s hub ring....and i remember reading some dont need them....anyone help? I in dyer need of some spacers.
Thanks
Old Jan 1, 2012 | 04:11 PM
  #686
Waiz's Avatar
Waiz
Thanks
Those do not have the rings installed.
The reason to run them is explained on the first couple posts of the thread:
https://my350z.com/forum/7149509-post4.html
Old Jan 20, 2012 | 04:26 AM
  #687
Deteria's Avatar
Deteria
Dropped on Tein S-Tech
Ichiba Spacers
15mm F
20mm R
Hankook Ventus Evo V12
245/40/18 F
275/35/19 R
Rear fenders rolled by AcidJake75.
Old Jan 20, 2012 | 07:06 PM
  #688
Brogan07's Avatar
Brogan07
Looks good. Did you need a camber kit?
Old Jan 20, 2012 | 09:37 PM
  #689
Deteria's Avatar
Deteria
No aftermarket camber kits. My rears are within spec. Front's are @ -1.6 and -1.8 deg camber. I should prolly get A arms... but meh.
Old Feb 3, 2012 | 08:13 AM
  #690
sry110's Avatar
sry110
Thinking about running 15mm spacers w/ built-in studs. My concern is torque on the spacer lugs. Seems to me that the proper procedure start-to-finish is as follows. Please correct me if I am wrong:
1) Remove wheels
2) Install spacers and torque spacer lugs to spec
3) Install wheels and torque wheel lugs to spec
4) After a test drive, check / re-torque wheel lugs to spec.
5) After 30-50 miles of driving, remove wheels and check / re-torque spacer lugs
6) Reinstall wheels and torque wheel lugs to spec
7) After a test drive, check / re-torque wheel lugs to spec
8) After 30-50 miles of driving, check / re-torque wheel lugs to spec.
It seems overkill, but based on thermal cycling of the wheel / hub / studs etc. and the possibility of the thread stress relieving, it seems like the safe way to go.
Old Feb 16, 2012 | 08:43 PM
  #691
Fenom's Avatar
Fenom
Default Need help from Wheel/Tire/Offset Gurus out there!
Hey guys, i just put on my Forgestar F14(waited for over 3 months) on my car, the wheel specs are 19x10 +20 front 19x11 +23 rear wrapped with Hankook V12 255/35/19 front, 285/35/19 rear. So far, i really love the look of it. It looks awesome on a black car with some concave looks for both front and rear. Although i like the way it looks right now, but i am thinking to poke them outwards a little bit to achieve more of a flush look, just a little bit maybe 10mm front and back since the wheels themselves are pretty wide and aggressive. By the way, my car is lowered on gf210s and rear fenders are rolled. I am thinking to purchase the H&R spacers http://www.mynismo.com/products/?id=4182 which is 10mm both front and rear. My question is, is this something that doable? and would it cause me problems?(rub, damage wheels/car). Sorry that i typed too much, just want to give out more info to get accurate insight on this matter. Thanks for reading!=]
Old Feb 16, 2012 | 09:05 PM
  #692
Waiz's Avatar
Waiz
Your answer can be found here.
Old Feb 16, 2012 | 09:50 PM
  #693
angelo350z's Avatar
angelo350z
1) Remove wheels
Sounds about right. When I had my spacers, I skipped step 4 and stopped at step 5.
Old Feb 17, 2012 | 06:53 AM
  #694
cb1's Avatar
cb1
+10mm all around
Meisters 19s 9.5 +23F 11 +17R
255/35/19 F 275/35/19R
Old Feb 17, 2012 | 11:08 AM
  #695
Fenom's Avatar
Fenom
Originally Posted by cb1
+10mm all around
looks good! thats similar to my wheel and tire specs, what spacers are you running? thanks!
Old Feb 17, 2012 | 12:30 PM
  #696
Waiz's Avatar
Waiz
He says 10mm all around in the post you quoted
Old Feb 17, 2012 | 02:46 PM
  #697
Fenom's Avatar
Fenom
Sorry, didnt make it clear, I mean what brand of spacers he is running..
Old Feb 17, 2012 | 03:50 PM
  #698
cb1's Avatar
cb1
^^ thanks bro!
I got it 2nd hand a while back From m3post.com
Ill find out. Ill post it up.
Old Feb 17, 2012 | 05:23 PM
  #699
Brogan07's Avatar
Brogan07
Just got word from the shop that my 07 with stock wheels/tires and 25mm spacers front and back DOES NOT rub at all after being lowered on Eibach Pro Kit springs (1", 1").
He also mentioned that it looks like no camber kit will be required.
*fist pump*
Will post a pic after I pick the car up tomorrow.
edit:
Old Feb 17, 2012 | 06:25 PM
  #700
TwoFastFurYa's Avatar
TwoFastFurYa
Anyone running Eibach Sportlines with 25mm on front touring V2's, and 30mm on the rears?
