FAQ: Official wheel "SPACER" thread!
Old Jul 13, 2012 | 07:03 PM
  #921
beinked's Avatar
beinked
I had someone step on the brake but it would still move a bit while tightening the nuts so I just used a small piece of 2x4 I had laying around and that did the trick. It just rained last night making the car look like I just came back from 4x4ing. I will wash the car tomorrow or the day after and upload some pics!
Old Jul 18, 2012 | 08:46 AM
  #922
goracerx's Avatar
goracerx
Need help finding shorter length replacement studs?
From JasonZ-Ya's post...
The Z OEM studs are M12X1.25 with a 14mm knurl at the head
FRONT OR REAR: M12X1.25x42 (42 mm length) OEM F/R replacement -
NAPA P/N 641-3210
AUTOZONE - 610-378.1 98353.1
I called ARP and they said they can't match those sizes. I don't get it, I thought someone posted ARP replacement part #'s?
Another post showed 20mm spacers with OEM studs protruding +3mm. I have 15mm spacers (3+5=Pie squared?), so I would need 34mm overall length studs.
My other options are:
1. taking the car to my fabricator and paying big time to have them professionally matched cut.
2. Selling the Ichiba's and buying Eibach's with extended studs which still requires removing and pressing in studs. Although I did see a thread where someone whacked them out with a hammer and they got pressed in when the lugs got torqued.
Where could I get "quality" steel studs, any sponsors here? I don't track the car, so I really don't need titanium or T71 aluminum but would want stainless or high grade steel that won't rust and/or strip easily.
Last edited by goracerx; Jul 21, 2012 at 01:37 PM. Reason: Found correct OEM stud sizes. Need -8mm shorty replacements.
Old Jul 24, 2012 | 10:11 AM
  #923
goracerx's Avatar
goracerx
http://www.jegs.com/i/ARP/070/100-7716/10002/-1
Reply from ARP with part # 100-7716. I'm really not sure how 72mm is 8mm shorter then 42mm. They must be using the governments budget calculator.
That means my only options are:
  1. Have OEM studs cut - 8mm
  2. Sell Ichiba v2 kit and buy Eibach kit with extended studs.
ARP extended is way to much to cut in half. RA's price for Raybestos brand w/ship+tax = dealer retail price. Finding a machine shop to cut them is like asking for a favor.
Old Jul 24, 2012 | 10:17 AM
  #924
JasonZ-YA's Avatar
JasonZ-YA
dude, when i went through this, i found that the measurements on studs vary...some measure from the end, others measure from the base of the knurl/mount face....
So;... the "mm" dimension given on their websites is complete crap unless you know from where the measurement began...get it?
I literally have a few sets of 10 studs in boxes too long or too short for my needs....
you have to email directly to each vendor and have them measure, provide a picture and hope they know how to use a damn ruler...
stoopid i know...
you literally have to email them this picture and tell them what you need:
-J
Attached Thumbnails FAQ: Official wheel "SPACER" thread!-stud-measurement.jpg
Old Jul 24, 2012 | 12:40 PM
  #925
terrasmak's Avatar
Keep V2, convert to V1 and get the studs from Ichiba or ARP, simple and easy.
Old Jul 24, 2012 | 02:21 PM
  #926
Lucky736's Avatar
Lucky736
Originally Posted by chrisjersey06
Thanks Jason, your reply was very informative and helped a lot.
Here's my contribution to the thread:
Car has no drop, stock 18" wheels, and stock tire sizes. This is with Concept Z Spacers in 30mm rear, 25mm front. I'm very happy with the look.
Alright so these are the same wheels and tires I have. Looks like 30MM fits perfectly at stock height in the back and the 25MM sticks out a touch further in the front. I DID read the entire post, all 45 pages, and see nowhere where someone is running these stock 03 Touring Style wheels with a 30/20 setup.
Two questions:
Any rub in the back on the 30MM? I realize tires can be designed differently etc but it appears even without the back being rolled, I am safe. Is this right?
Also, I believe 20MM in front would make it look like the 30MM on the rear as far as how the tire sticks just a touch inside the fender line at the top. Is there any issue running the 30/20 setup as far as the VDC is concerned or are the only issues there strictly with tire size. I know VDC is more than just "traction control" in the regular sense and I don't like having electronic anything kicking in sooner than it is supposed to.
Thanks in advance guys and gals.
BTW I may do a MILD drop in the future, maybe 1/2 inch tops, but I am not looking to dump it anytime soon, or anytime for that matter. Not sure if this will play into the above or not.
Old Aug 1, 2012 | 05:02 AM
  #927
sry110's Avatar
sry110
Two questions:
Just addressing the first question: I don't think you will rub even without fenders rolled, at that ride height and "Stock" camber settings. As the suspension compresses, the wheel effectively cambers inward (more negative), which will give you plenty of clearance between the tire and the fender lip.
Old Aug 1, 2012 | 05:43 AM
  #928
Lucky736's Avatar
Lucky736
Nice. I thought so but at the same time I didn't want to find out after the fact. Making sure I have enough set aside to do it right, however that may be.
Old Aug 1, 2012 | 05:51 AM
  #929
sry110's Avatar
sry110
No problem. As for your additional questions:
2) VDC will only be affected by tire diameters, and not overall offset/width. As long as you are sticking to OEM tire diameters front and rear, you will have no VDC issues.
3) Unless you install adjustable camber arms, when you eventually do your mild 1/2" drop the wheels will just camber inward (negative) that same amount that they would right now if you were to compress your stock suspension by the same 1/2". So you should still have no rubbing.
Old Aug 1, 2012 | 06:03 AM
  #930
Lucky736's Avatar
Lucky736
Yeah, I was hoping to not have to get into adding suspension components like adjustable camber arms etc. I think a simple set of H&R springs, and maybe some accompanying shocks, would be sufficient for where I want to end up with it.
Old Aug 1, 2012 | 07:10 PM
  #931
xTimx's Avatar
xTimx
i have a different Q on spacers.
do you get a better turning radius when you have spacers on? or no?
Old Aug 2, 2012 | 03:16 PM
  #932
Riley Cordova's Avatar
Riley Cordova
Default Spacers for Stock Suspension
I am considering putting spacers onto my Z right now, or at least I want to.
I am not exactly too sure what sizes I need to get and go for, yes I have used the search feature and I didn't pull up too much useful information.
What I have planned is Spacers then coilovers and lower it and have a nice stance.
What size spacers should I be looking for?
Thanks in advance
Old Aug 2, 2012 | 03:38 PM
  #933
Waiz's Avatar
Waiz
Merged...
Search here first, a boatload of info is in this thread!
Old Aug 2, 2012 | 03:42 PM
  #934
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Thanks in advance
Personally, I'd recommend spacing the wheels out after you've lowered the car and gotten your alignment dialed in. After that, measure and purchase the right size for your needs.
Old Aug 2, 2012 | 04:07 PM
  #935
Lucky736's Avatar
Lucky736
Two questions:
Anyone have pics of a 30/20 setup? Preferably with the same OEM wheels or another 18" OEM wheel.
Thanks again everyone.
Old Aug 5, 2012 | 01:17 PM
  #936
Z33Garage's Avatar
Z33Garage
I just picked up 2 eichiba 25mm spacers cheap locally.
I am paying too much stuff off right now ( and trying to finish my AR build)
Question: Can I run these 2x 25mm spacers in the rear? Will it look stupid?
Thanks guys
Old Aug 6, 2012 | 11:39 AM
  #937
VMRWheels's Avatar
VMRWheels
What wheels? OEM?
Whether something will look bad or not is somewhat subjective. Just depends on your taste.
Old Aug 6, 2012 | 11:43 AM
  #938
Z33Garage's Avatar
Z33Garage
Originally Posted by VMRWheels
What wheels? OEM?
Yeah OEM 18s. I installed em last night. Looks good actually I think. I will wait to find some used for the fronts. My friend gave me 1 spacer....
dafuq am I going to do with 1 spacer? melt it maybe....
Old Aug 6, 2012 | 11:51 AM
  #939
VMRWheels's Avatar
VMRWheels
Can't do much with one spacer haha. Plenty of choices out there for inexpensive wheel spacers.
Old Aug 6, 2012 | 11:53 AM
  #940
Z33Garage's Avatar
Z33Garage
Indeed, I will probably wait to find some used ones as the car modding is on the backburner for now....but soooon.... -____-
