FAQ: Official wheel "SPACER" thread!
Old Dec 3, 2015 | 06:00 AM
  #1301
travlee's Avatar
travlee
Master
didnt you post this same thing in the wheel spacer thread?
Old Dec 3, 2015 | 06:13 AM
  #1302
Squeaky Z's Avatar
Squeaky Z
Yea i need a solution to this any ideas?
Old Dec 3, 2015 | 06:17 AM
  #1303
turboed350z's Avatar
turboed350z
Sell it and get proper sized wheels...
Old Dec 3, 2015 | 06:19 AM
  #1304
jhc's Avatar
jhc
General & Tech Moderator
20s will ruin your bushings.
Old Dec 3, 2015 | 06:20 AM
  #1305
turboed350z
Originally Posted by Squeaky Z
Im new to this as well so hopefully this is just straight forward but i got some rohana rc22 not staggered on a deal. Im going to call them and see if they have the rear spoke clearance or not.
So i now have (4) 20" rims already tired. Width is 9" for all four. Bolt pattern; 5x 114.3 and they're offset is +35 all around
I basically test fit these onto my 350z that is lowered on Bilstein pss10s but setup to almost a maximum height. I think im going to need my fenders rolled if im correct? And my rears fit fine with no spacer (they clear my brembos) but the front hit against my caliper by about 2mm when i tried test fitting with a 8mm spacer.
I just want these rims to fit and not rub but also look good any ideas on the perfect spacer combo i need? I know i need a minimum of 12mm on the fronts to clear.
Is it smart to run spacers in the front and not back if theyre not staggered?
I also already purchase hubcentric rings in the proper bore size. I bought 2 sets to be sure (one plastic gorilla brand) one aluminim set off ebay both at the bore sizes 66.1 to 73.1 (which is what my aftermarket rims are)
So suggestions on spacers please
So many things wrong w8th these wheels....
Old Dec 3, 2015 | 06:21 AM
  #1306
Squeaky Z's Avatar
Squeaky Z
If only this was an option ha. What are the proper offsets + specs on rohana rc22
I would optimally have bought 20 x 9 for the front and 20 x 10 or 20 x 11 for the rears. Might upgrade in the future. But trying to figure out if i can fit these well
Old Dec 3, 2015 | 06:22 AM
  #1307
turboed350z
Can you fit it? Sire, should you? No...
  #1308
Squeaky Z's Avatar
Squeaky Z
In what? I put on spl rear arms + toe bolts etc anx pss10s. Thinking of putting spl front arms jn thd future but want to figure out these rims first
Old Dec 3, 2015 | 06:24 AM
  #1309
Squeaky Z's Avatar
Squeaky Z
Why so? Whats my best option basically without killing my wallet too much. Worst comes to worst ill srll these n get proper offset ones which if someone told me what they are ++?
Old Dec 3, 2015 | 06:26 AM
  #1310
turboed350z
Take a look in the wheel section. Plenty are running 19×9-10+12-20
Old Dec 3, 2015 | 06:42 AM
  #1311
Squeaky Z's Avatar
Squeaky Z
Im set on the model and style though. I want rc22s; i think a new set of thrm cost $1600 for the rims alone and i can sell these for about $1250 easy. But what spacers and such would i need if i want this set to fit until then
Old Dec 3, 2015 | 06:44 AM
  #1312
Squeaky Z's Avatar
Squeaky Z
Then what do i do; resell them or try to fit them. Id buy new 20" that fit my car from the manufacturer but im set on 19 or 20"
Old Dec 3, 2015 | 06:51 AM
  #1313
turboed350z
Not worth the trouble...
Old Dec 3, 2015 | 06:52 AM
  #1314
Nismo350z#0310's Avatar
Nismo350z#0310
20x9 sounds so ugly looking
19 is max I would ever go on a Z, but it's just an opinion and everyone has got them!
Old Dec 3, 2015 | 06:57 AM
  #1315
Squeaky Z's Avatar
Squeaky Z
Well does anyone know what i need to do to perfectly fit thesr on; otherwise gunna need to buy new ones n sell these. And im going to have a seperate 18" set for when i go track
Old Dec 3, 2015 | 06:58 AM
  #1316
turboed350z
Imo 18s are the perfect size! You get looks AND performance.
Old Dec 3, 2015 | 06:59 AM
  #1317
turboed350z
No one knows how flush you want it, how lower you are, chances are youll hit the fenders going over a bump, but just to answer your question, youll need a spacer in the 85mm range
Old Dec 3, 2015 | 07:00 AM
  #1318
Squeaky Z's Avatar
Squeaky Z
Isnt it just 1 spacer in the front though or do i just space at 20/25mm. You guys know more as to what wheel will fit in with what spacer size. Basically
If someone can tell me exactly what spacer i need for front n back that would be perfect. Ill find out if the back of the rims have space for the oem bolts
Old Dec 3, 2015 | 07:03 AM
  #1319
travlee's Avatar
travlee
Master
20s are big and heavy, have a rough ride, and degrade performance. they make those wheels in 19s
http://rohanawheels.com/wheel/rc22/
  #1320
Squeaky Z's Avatar
Squeaky Z
Wait are you joking or no lol. Im preety sure a 12mm spacer on the fronts clear my brembos.
As i said my offet is +35
also what would be the proper rim size / offset for these in 20" then incase i want to order new ones. I basically want a 20" set. A 18" track set n i already have a 17" winter set lol
