350Z How to's
Old 04-19-2003, 08:01 AM
tonkadog
tonkadog's Avatar
Default 350Z How to's
Thought it would be a lot easier for people looking for how to's if they were put together in one thread. I know I have missed alot, if you know where it is, please add to the list - explain what the how to is and paste the link.
How to take apart the dash
http://www.scafremon.com/dashremoval/dash_removal.htm
How to remove the door panels
https://my350z.com/forum/showthread....&threadid=7995
How to run speaker wires to the doors
https://my350z.com/forum/showthread....threadid=25677
How to wire factory NAV with an aftermarket HeadUnit
https://my350z.com/forum/showthread....threadid=18333
How to remove center console and run RCA/speaker wires from glove box to dash:
https://my350z.com/forum/showthread....threadid=26620
How to run power/ground wires from battery to glove box:
https://my350z.com/forum/showthread....threadid=26618
How to mount radar detector under rear view mirror:
https://my350z.com/forum/showthread....threadid=18579
Old 04-20-2003, 12:21 PM
tonkadog
tonkadog's Avatar
Old 04-22-2003, 03:10 AM
tonkadog
tonkadog's Avatar
How to take apart the rear speaker panels:
https://my350z.com/forum/showthread....threadid=26837
How to remove the shift ****:
https://my350z.com/forum/showthread....threadid=25516
Old 05-12-2003, 07:47 PM
alphared
alphared's Avatar
Originally posted by KJ-350
does anyone have one for getting out the far rear panels of the hatch? I plan on layer pretty much everything behind the seats and into the entire hatch area
The back is pretty easy to remove.
Start with the very back, pop the bottom out (by pulling forward) Then pull straight up. The clips are on top along the lip of the trunk ( I snap 3 of them by pulling forward instead of up)
From there the rest is pretty straigh forward of pulling up or out.
For the strut bar panels, you need to pull the side panels out first (the ones near the door that runs over the rear speakers)
It should take you no more than 1/2 to remove all the panels and foam.
Now, can someone post some pic of it not removed. I had them off for almost a month and not sure If I remember what goes where
Old 05-17-2003, 11:35 AM
tonkadog
tonkadog's Avatar
How to take apart the rear speaker, sub, quarter panel area:
Old 06-25-2003, 03:49 PM
honoluluZ
honoluluZ's Avatar
Default Another Radar Install
Here's another Radar install...looks clean
https://my350z.com/forum/showthread....threadid=33884[/URL]
Old 07-22-2003, 11:17 PM
MY350Z.COM's Avatar
diy kick panels
https://my350z.com/forum/showthread....threadid=31971
bose fix
https://my350z.com/forum/showthread....threadid=19106
Old 08-07-2003, 03:08 PM
JamHooks
JamHooks's Avatar
Does anyone know how to do the grounding kit? My radio is screaming when I turn it on. I can drownd it out with music but, i'd rather do it right.
Old 08-07-2003, 04:39 PM
AndyB
AndyB's Avatar
Default How Tos
One of the other forums I frequent (Durango Owners) has some FAQ and How To pages that are not forums. They are things that get "promoted" from a thread to a special area.
It is a great feature and it really does cut down on repeat questions.
I am not a moderator or anything, but I would like to humbly propose this type of idea for this group.
Old 08-10-2003, 11:40 AM
liljerk
liljerk's Avatar
I copied some of these howto's to my website for easy access.
http://liljerk.morpheus.net/350Z/
Old 08-30-2003, 10:52 AM
mrdoubleb
mrdoubleb's Avatar
what about the "Bose" sound system ?? we get that here in Holland not the Clarion stuff
Old 09-05-2003, 11:19 AM
hokie350
hokie350's Avatar
How about "HOW TO" hook up an aftermarket LCD, conenct ground wires, connect sound to headunit, and run video cable to the back glovebox
Old 09-07-2003, 02:37 PM
MySunset350Z
MySunset350Z's Avatar
heres another radar instal. i did i side mount rather then a center mount.
https://my350z.com/forum/showthread....threadid=26233
Old 09-08-2003, 03:09 AM
Bahraini350Z
Bahraini350Z's Avatar
I have a stupid question!!! How can I change sides of the cassete with having to remove it from the unit??
p.s. I have the BOSE (CD+cassette+radio) system
Old 09-16-2003, 02:52 PM
sparky3Z
sparky3Z's Avatar
I'm sorry but I do not understand your question. What do you mean by "changing the sides of the cassete?"
Old 09-16-2003, 08:12 PM
Bahraini350Z
I mean if ur listening to side A on the cassete and you wanna change side to B!! it seems to be impossible to do so!!
Old 09-17-2003, 06:33 AM
sparky3Z
sparky3Z's Avatar
I've never done that so I don't know. Have you looked in the owner's manual?
I will try my cassette player and see if I can make it reverse.
Old 09-18-2003, 02:11 PM
sparky3Z
sparky3Z's Avatar
Default Bahraini350Z
You can reverse or switch sides of an audio cassette by pressing the "TAPE" button at the top of the Bose head unit while a tape is playing.
Old 09-22-2003, 01:11 PM
Bahraini350Z
Default Re: Bahraini350Z
Thanx man for the tip couldn't they make a better switch
Old 09-24-2003, 05:31 PM
G35C-Man
G35C-Man's Avatar
Escort 8500 and ZR3 Laser Shifter Install
Quick Reply: 350Z How to's
