Subwoofer Boxes - Recommend one ?
Old 04-01-2019, 11:01 AM
JCat
JCat's Avatar
Default Subwoofer Boxes - Recommend one ?
I have owned and used 2 different sub woofer enclosures since I purchased this vehicle in 2004. The first one was a huge box with two 10's and the second was an "under the strut bar" with two 10's.
The big box used all my trunk space, so I switched t the under the strut bar box. Neither box was ported.
I have (2) JL Audio 10's, but I am not sure whether or not to continue using both. I am also using a JL Audio JX 1000 amp.
In your opinion, what sub enclosure would you use ? (Not nec. the ones that I have)
Ported or not ?
1 or 2 subs ?
I realize sound can be a personal preference. I would like to hear from 350Z owners who are happy with what they got (or experienced).
striker27 (04-06-2020)
Old 04-01-2019, 08:37 PM
mr. sparco
mr. sparco's Avatar
Over the years: I went from from a single 12" RF sub in a sealed box, to two JBL 10s sealed, to a single band pass JBL 10, now I'm down to a single sealed 8" Kicker CompR stored away in the cubby where the Bose sub would be. I still enjoy listening to a well balanced crisp system, just don't care for the bass vibrating the entire car and what feels like my heartbeat being thrown off, if that makes any sense.
The following 3 users liked this post by mr. sparco:
aiko.z33 (06-07-2023), JCat (04-02-2019), Spike100 (04-02-2019)
Old 07-10-2019, 07:18 PM
ntwillie1
ntwillie1's Avatar
I use the JL Audio subwoofer enclosure that is specifically made for our cars. It houses 2 x 10" subs. A year or so ago one of the subs blew out and they no longer made it. I purchased two of the replacement/newer subs and put them in the box and they work perfect. I forget the model subs. It sounds good, clean, hits hard, and blends right in. I have them paired to a JL Audio 5.1 sub which also drives my front components, rear components, and the subs. I would recommend going on their website and checking out the enclosure. I've had mine for a little over 12 years now and love it. A little off topic but I recently started dynamiting the areas behind the factory speaker locations and it has made a difference for me in terms of reducing rattle and i just feel like it gives cleaner sound as well. I would recommend this to anyone interested in a nice home project and a bit better sound.
The following 2 users liked this post by ntwillie1:
khnitz (07-12-2019), striker27 (04-06-2020)
Old 07-12-2019, 12:29 PM
khnitz
khnitz's Avatar
Originally Posted by ntwillie1
I use the JL Audio subwoofer enclosure that is specifically made for our cars. It houses 2 x 10" subs. :snip: I've had mine for a little over 12 years now and love it.
Good to hear! I picked up a JL audio enclosure (subs not included) off CL last year and will install it this winter as part of a sound-system upgrade project. I have two 10 inch Infinity Reference 1000S subs ready to install in that box, and I'll be upgrading the front and rear speakers to Infinity Perfect 600 components. Also have an Alpine 5-channel amp that I'll use to power it all to start. So, to the OP, I can provide feedback on all that next Spring, most likely
Old 07-13-2019, 04:58 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Are any of us really ever happy...
Ive done
Single 8
Double 8
Single 15
Single 10
All in sealed boxes, and just picked up a ported box to try out...
All have done a pretty good job...
All in the hatch.
Old 03-24-2020, 09:01 AM
Tahag Meh
Tahag Meh's Avatar
Default DIY build - 2 8” fiberglass enclosures.
I built these to maximize trunk space. They don’t hit hard due to the small sealed enclosures but the overall sound of the car is balanced and full. I’m happy with them.
The following 4 users liked this post by Tahag Meh:
1BaddLSZ (04-02-2020), JCat (07-28-2020), khnitz (03-24-2020), Zelduh (03-24-2020)
Old 03-24-2020, 09:57 AM
khnitz
khnitz's Avatar
They look fantastic, though - great work! Are those 8" or 10" subs? I have a JL Audio Stealthbox and some Infinity 10" subs waiting to be installed in my Z.
Old 03-24-2020, 03:10 PM
Tahag Meh
Tahag Meh's Avatar
Thanks! First time doing fiberglass...took way more time than I was anticipating but I learned a lot. I’ve seen a couple others in that spot that garnered more cubes but I had to sacrifice some size for the OEM aesthetic I was chasing.
8” Rockford Fosgates. I tried a couple others (Alpine S and Morel) and the RF’s sounded the best in those enclosures.
khnitz (03-24-2020)
Old 04-05-2020, 08:46 PM
Christine Crone
Christine Crone's Avatar
Default SRQ Down firing versus custom front face in my Roadster
I’m the owner of a 2006 Roadster.
Whats better?
the SRQ down firing box or a custom front facing sub in the cubby behind my seat?
will the SRQ rattle everything if I lay Kilmat in the enclosure first?
and if I lay it, should I lay it in such a way that it creates a box back there?
whats the difference in sound between the 2 options?
Old 04-06-2020, 04:17 AM
Drey350z
Drey350z's Avatar
If you realy want bass. I have a custom box built into my spare tire spot. So I don't have a spare tire in my car. It's one 15" woofer.
Old 06-13-2020, 07:09 AM
R8D
R8D's Avatar
Whats better?
If you have the option for front firing, that would be more ideal. Additional bonus if you use fiberglass vs. MDF to create the box in the cavity, so that you can increase the size of the enclosure.
I currently have the downfiring box with a 10w3, would sound better firing into the cabin IMO (I'm looking at my own options as well... roadster means no trunk builds).
Old 06-23-2020, 06:21 AM
bugmenot
bugmenot's Avatar
I plan to install two 10-inch subwoofers, I think that this will be quite normal. I found them by accident when I was looking for internal enclosures for my computer see this . I really love the clean and loud sound of music, I hope that everything will work out when I do it and I will write it.
Old 07-25-2020, 11:07 PM
schwag80
schwag80's Avatar
Default JL Stealthbox with W6's
I have 2 JL 10W6V3 in a JL Stealthbox. Tight fit but I made a couple of spacers to give them room to breath. I have an HD1200/1 powering them along with plenty of sound deadening throughout the car. They play very loud when needed but most of the time I have to tone them down a bit.
Next year I want to try ported. Hopefully this helps because Ive seen people post that W6's won't fit in that enclosure that is designed for W3's but they do and they sound pretty darn good.
The following 2 users liked this post by schwag80:
JCat (07-28-2020), khnitz (07-26-2020)
Old 07-27-2020, 05:10 PM
dboyzalter
dboyzalter's Avatar
Simple new box.
JCat (07-28-2020)
Old 12-15-2020, 05:53 PM
rodbass
rodbass's Avatar
My new (to me) Z convertible has NO bass. Pretty sure the sub behind the Bose grille is either missing or broken. So I figured I could simply buy a 10" sub and replace it. I now understand it's not so simple. Apparently I need to have the sub mounted in a box. Can anyone recommend one I can buy that will fit in the factory location? (The right size, the right shape, simple installation, etc.)
Old 12-15-2020, 07:53 PM
rodbass
rodbass's Avatar
What is the size of the space behind the sub? Will it fit a pre-made box such as this?
AmazonSmile: Bbox E10ST Pro-Series 10” Single Sealed Wedge Shaped Subwoofer Enclosure: Car Electronics
Old 12-16-2020, 01:36 PM
travlee
Master
travlee's Avatar
Received 9,054 Likes on 6,520 Posts
Grab a tape measure and go out to your car....lazy ***
Old 12-16-2020, 01:49 PM
rodbass
rodbass's Avatar
travlee-
If I knew how to open up the panels and measure, I wouldn't ask in a forum. I'm an ordinary car owner, not a car stereo installer.
This is supposed to be a forum for 350Z owners to help each other, not insult each other.
Old 12-16-2020, 02:37 PM
travlee
Master
travlee's Avatar
travlee-
want to know how to remove that panel......pull. the car has been out prob as long as you are old,, if you are buttnurt over that, you will really dislike me when I am grumpy. Maybe a safe space with crayons is more suiting for you
Z423
06-08-2023 05:20 PM
tw8715
02-19-2010 01:05 PM
SuperBlack350z
09-28-2008 08:06 AM
geomark
03-22-2008 09:56 AM
sean6tt
07-18-2003 03:59 PM
Quick Reply: Subwoofer Boxes - Recommend one ?
