Ditched my vortech: Built motor, greddy twins, budget build: updated 9-18-2010
Old Nov 5, 2011 | 05:12 PM
  #261
Cux350z's Avatar
Cux350z
hatersgonnahate
Working on getting a tune scheduled. Work has got me on the road again though which makes it tough.
Drove the car this afternoon...parked in garage and just checked the floor........all clean.
Old Nov 12, 2011 | 05:24 PM
  #262
HotRodG35's Avatar
HotRodG35
Chris,
Been awhile since touched base with you. Cant believe your still dealing with oil leaks. My guess its the sandwich plate, using gaskets are not much of advantage when not used in OEM application.
Were the Okada coil packs worth the investment ?
Good luck.
Old Nov 12, 2011 | 05:40 PM
  #263
Cux350z's Avatar
Cux350z
hatersgonnahate
So far no leaks as of the last round of parts
Replaced the sandwich plate.
Will know if the Okadas were worth it once I get a tune. They are pretty though.
Winter is about to hit, no reply from fp. I am thinking wire tuck time.
Old Nov 14, 2011 | 08:59 PM
  #264
HotRodG35's Avatar
HotRodG35
Chris,
Hit me up if you need assistance with wire tuck. I plan on finally being done with current stage of mods by Christmas.
Was going to put a roll cage in by april but decided to work on exterior cosmetics for now.
Old Jan 1, 2012 | 03:32 PM
  #265
Cux350z's Avatar
Cux350z
hatersgonnahate
^you get her done?
I have been driving the z around some and datalogging a bit. Binder gave me some haltech pointers that have worked out pretty well. Driveability is so much better.
Havent started the wire tuck. Even with time off from work I stay busy, wife keeps me busy, falling trees ect.
Old Jan 1, 2012 | 04:37 PM
  #266
binder's Avatar
binder
Originally Posted by Cux350z
^you get her done?
I'm glad it helped. I can't take all the credit though. Raj (rcdash) and rich (str8dum1) both spend a great deal of time helping me with my haltech problems so without them i wouldn't know half of what i do.
I need to do it on mine too. I said i would over the winter but break is almost up and i just don't feel like it.
Old Jan 1, 2012 | 07:57 PM
  #267
suprasam's Avatar
suprasam
I'm considering a wire tuck too. Just need a good long weekend to focus. Ah, the work on these cars never ends!!!!!!!!!!!
Old Jan 2, 2012 | 12:35 AM
  #268
Resmarted's Avatar
Resmarted
Did you end up going to pro-efi?
I'm going to have to learn all this haltech stuff... Who knows if I'll be able to afford tuning for a while
Old Jan 2, 2012 | 11:52 AM
  #269
binder's Avatar
binder
no. The only reason i wanted to switch was for the flex fuel situation but now i'm just all e85.
the second issues is the cams not being on before i do a WOT pull first. Hopefully i will have that worked out soon.
Neither of those reasons was worth the money i would spend (probably over a grand after i sold my haltech) plus having to learn a whole new software. It also came to my attention that the end user software for the proEFI isn't the same as the tuners use.
Old Jan 2, 2012 | 03:11 PM
  #270
Resmarted's Avatar
Resmarted
I keep reading about this cam issue on the haltech. Which sucks because I want to run 272's and I feel the more aggressive duration/lift will exacerbate the timing being off... I'll talk to the dynosty guys later this week and see what they have to say (I'll see if the re-flash I want them to do can cover that) and let you know (Although I bet you've already talked to hal about it lol).
That's really weak that the pro-efi has a different tuning software. I didn't know that either. I have to admit those gauges available for pro-efi are waay sicker than the racepack.
Old Jan 2, 2012 | 03:49 PM
  #271
binder's Avatar
binder
it has nothing at all to do with timing.
From a fresh restart the cams are not active (0* advance). They do not become active until you do a WOT pull all the way to redline. Then they start functioning normally. That's the issue. Doesn't matter what brand, size, duration, etc cam it is. This is only an issue so far with 2003 g35's. I have heard of a few evo's and a 2006 350z that also has this problem (from the haltech forums). it's hard to say how many people really have this issue but never even open a laptop and look while the car is running.
Old Jan 2, 2012 | 05:19 PM
  #272
Resmarted's Avatar
Resmarted
Huh that's really strange.
Well NOT MY PROBLEM
Jk
That really sucks. How does the car pull on that first initial wot run? I'd imagine not that great.
Old Jan 3, 2012 | 06:07 AM
  #273
binder's Avatar
binder
Well NOT MY PROBLEM
Jk
the only thing affected is spool. Rich has the same problem and his peak numbers were the same. I'm assuming the differences in mine at the top end are due to the clutch slipping.
Attached Thumbnails Ditched my vortech: Built motor, greddy twins, budget build: updated 9-18-2010-cams_nocams_18psi.jpg
Old Jan 3, 2012 | 06:21 AM
  #274
str8dum1's Avatar
str8dum1
fixed
the only thing affected is spool. Rich had the same problem and his peak numbers were the same. I'm assuming the differences in mine at the top end are due to the clutch slipping.
no phasing issue with my proefi.
Old Jan 3, 2012 | 01:28 PM
  #275
binder's Avatar
binder
Originally Posted by str8dum1
fixed
ya ya ya, i meant with the haltech
and mine is fixed as of today. Hal logged into my computer remotely and made a new firmware update that fixed it. YAY
Old Jan 3, 2012 | 01:45 PM
  #276
Cux350z's Avatar
Cux350z
hatersgonnahate
you upgrade to 1.10?
Old Jan 3, 2012 | 02:38 PM
  #277
Resmarted's Avatar
Resmarted
1.10 is out?
Old Jan 3, 2012 | 02:40 PM
  #278
Cux350z's Avatar
Cux350z
hatersgonnahate
been out. there is even a minor revision.
Old Jan 3, 2012 | 04:35 PM
  #279
Resmarted's Avatar
Resmarted
Huh, well I think mines loaded with 1.08, maybe 1.09 (seeing as I just downloaded the first version I found), but then again it's been a few months since the car has cranked over
Isn't 1.08 the most proven on the vq though?
PS Damn Cux, I really jacked your thread sorry :P
Old Jan 4, 2012 | 08:58 AM
  #280
binder's Avatar
binder
they don't release them until they have been tested. 1.10.2 i think is the latest manager and 1.10.1 or something is the latest firmware. Newest firmware comes with the newest manager.
