Cass007.... ver 5.0
Old Nov 4, 2010 | 04:35 AM
  #321
Cass007's Avatar
Cass007
Originally Posted by XKR
What happened Chris....You lost my phone number....I know I was out of the country....but my AT&T phone works everywhere
You are still at the top of the list Mike. I didn't want to bother you until I have a confirmed sale.
Rich - I was thinking more like BIG vynils down both sides... you know, fast & furious style
the only two losers that have had the kits on and off so many times the nuts and bolts are wearing out
Old Nov 4, 2010 | 05:56 AM
  #322
XKR's Avatar
XKR
....You know I am just messing with you.... I can't help it
Old Mar 18, 2011 | 11:30 AM
  #323
Cass007's Avatar
Cass007
BUMP
Almost back from the dead...
Cass007.... ver 5.0-2011-03-18_08-32-07_572.jpg Cass007.... ver 5.0-2011-03-18_14-26-56_21.jpg
Found a few wiring issues...
Cass007.... ver 5.0-2011-03-18_12-09-53_869.jpg Cass007.... ver 5.0-2011-03-18_12-10-19_446.jpg
and of course I am making some upgrades... Cusco front and rear sways
If all goes well I will have the engine in tomorrow and the car back on the ground next week. I'm keeping my fingers crossed and hoping to be ready for ZdayZ.
Old Mar 18, 2011 | 11:50 AM
  #324
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Thank You Sharif. You may be hearing from me. I only wish two things: your shop was closer; I had just dropped off my car and a pile of money at Forged in the first place
If you want to do some charity work and help turn around the longest streak of fail in the F/I forum in exchange for some HUGE Forged logos on my car and some serious forum nuthugging let me know
VERY IRONIC considering the context of that quote by Jeffie contained in your sig.
Regardless... Glad to see the BUMP with some progress. Hope you get back on the road soon without further problems.
Old Mar 18, 2011 | 11:52 AM
  #325
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
I hope you have better luck this time around. I would have given up by now.
Old Mar 18, 2011 | 12:08 PM
  #326
rh_334's Avatar
rh_334
Glad to see progress!
Old Mar 18, 2011 | 12:55 PM
  #327
superchargedg's Avatar
superchargedg
Damn Noobs
Hell yes Chris!!!
Old Mar 18, 2011 | 02:22 PM
  #328
graffkid732's Avatar
graffkid732
Nice man good luck, hope it all works out this time for ya.
Old Mar 18, 2011 | 03:09 PM
  #329
0jiggy0's Avatar
0jiggy0
Someone please tell me he chose someone different to work on the car this time?
Old Mar 18, 2011 | 03:34 PM
  #330
ToastZ's Avatar
ToastZ
Good luck, Cass !!! See you at Zdayz. This year is shaping up to be a good one.
Old Mar 25, 2011 | 12:14 PM
  #331
Cass007's Avatar
Cass007
The engine, trans, turbo kit and everything else is back on the car and the car is on the ground for the first time since last June
I have learned a ton of things during this process. The core support, AC condenser and radiator look easy to put back in, but were a complete PITA. I must have put it on and taken it off 5-6 times till I got everything on where it belonged and assembled in the proper order. The steering knuckle was another learning curve as well.
I can now say I installed a cat-back exhaust, sway bars and everything else. I feel proud, but will feel even better if the car starts and runs next week. I let the fuel system prime and so far no leaks.
The car seemed to fight me most of the way (probably because I didn't really know what I was doing), but in the end I was victorious. However, when putting the front under brace back on a socket slipped and hit me in the face. I have a nice cut on the bridge of my nose and may get a black eye or two as well. I could almost here the car giggle a bit when it happened
I just have to see if I can chase down a stray connector for the fuel evap switch that was missed when the wiring harness was hooked up. This would be easier if I hadn't done that custom tuck a while back, but its whatever. Off to remove the plenum and such for a second time, same old story
Old Mar 25, 2011 | 12:23 PM
  #332
Sylvan Lake V35's Avatar
Sylvan Lake V35
After reading that i might just leave my stock engine in one more year. I hate swapping everything hopefully this is your last time
Old Mar 25, 2011 | 12:27 PM
  #333
rh_334's Avatar
rh_334
and i will be going through this again soon
Congrats on getting it back together, cant wait to see some new #s
Old Mar 25, 2011 | 12:44 PM
  #334
Barnabas's Avatar
Barnabas
National Z Club President
GLAD YOUR ON YOUR WAY CASS!!!! Cant wait to race you
Old Mar 25, 2011 | 12:52 PM
  #335
superchargedg
Damn Noobs
Finally we can say Chris is close to be back on the road to recovery.BTW Barney he will stomp you.....lol.
Old Mar 25, 2011 | 12:57 PM
  #336
Barnabas's Avatar
Barnabas
hhahaha I know I just have yet to see his car running at anything over stock block power.
Old Mar 25, 2011 | 01:23 PM
  #337
str8dum1's Avatar
str8dum1
why'd you even separate the 3? Just remove it as 1 unit. 2 radiator hoses a few plugs and its off.
Old Mar 25, 2011 | 01:46 PM
  #338
GreenGoblin's Avatar
GreenGoblin
Awesome Chris, glad to hear that you are getting back in action soon. On the wire harness did you figure out what caused the melt? Was it to close to something hot, or a short? What is the first plug that is melted? The second is the condenser for the coil packs.
Old Mar 25, 2011 | 02:29 PM
  #339
Cass007's Avatar
Cass007
I took it off that way and then attempted to put it back in as one piece, but it would not claer the belts and such on the engine, then the AC lines were getting caught up too.
Not enough heat sheilding after I gutted the harness. The first plug was the factory knock sensor, it welded itself together with the harness clip. I hope my patch job on that is functional.
I found the last connection after removing the upper plenum, it was routed under the intake and looked like part of the PF cooling mod. All done now
I went to put on the oil filter and its the wrong one... classic. Oh, my wife came home, saw my face and asked what happened. I told her and she doubled over with laughter... love that girl
Old Mar 25, 2011 | 02:31 PM
  #340
Cass007's Avatar
Cass007
Your adopted and your parents don't love you
