Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement
Old Oct 12, 2012 | 01:49 PM
  #261
aln's Avatar
aln
Originally Posted by binder
After firmware 1.10 upgrade with my g35 I lost cam sensors until I did a full pull to redline then my cams would start working. Hal had to log into my car and change some parameters in my firmware. I guess the range was just slightly more narrow than what my car was giving causing the haltech to act like they were gone. Contact hal and he might be able to adjust your firmware.
Like manually edit the firmware bin file?
Last I heard it's with R&D in Haltech.
Old Oct 12, 2012 | 01:51 PM
  #262
aln's Avatar
aln
Originally Posted by MR RIZK
Take this as a grain of salt but based on what I see on my Z this is normal when using the Haltech harness based ecu. For me the cam timing will always take a bit of time before it starts working. It is like the ecu waits a pre-calculated time/scenario before it starts targeting timing. With the Haltech Pro Plug-in I do not see the same symptoms from memory.
you got the standalone now and it's not there anymore is that what you're saying? I don't think it's anything to do with 'time' rather behavior of the car when you have the RPM set higher then OEM. Kinda takes away from the harness or sensors too?
Old Oct 14, 2012 | 06:49 PM
  #263
binder's Avatar
binder
It's firmware. The parameters of what the normal range is can be adjusted.
Old Oct 14, 2012 | 08:12 PM
  #264
meatbag's Avatar
meatbag
Im still on the hunt for some good PID settings. Every time I think I get them close enough I see too much deviation the next day.
I was told a new firmware release might be coming to fix the issue. The harness style boxes didn't seem to have this problem so they must have had a different set of control variables or something.
Old Oct 15, 2012 | 02:23 AM
  #265
Keyser's Avatar
Keyser
It's my Zed that has the issue with the VVT on the Haltech.
We dropped the idle rpm to 800 and the Haltech works fine again - as long as you let the engine warm up and the idle drops below the 850rpm point.
Downside is mine does not like the idle that slow and tends to hunt a bit.
I emailed Hal he sent me a firmware upgrade but it hasn't solved the problem.
I'm waiting for a reply from Haltech.
We put the ECU into an NA 350z and set the idle to 1100 and got the same result so it seems it is the hight idle speed to blame for the problem.
Old Oct 25, 2012 | 03:19 PM
  #266
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Default Cold Start Issues
I have the new version of the Haltech on my JWT TT G35. Works great, but now that the weather is getting cold, when I leave it outside all day, and try to start it at the end of the day, it doesn't start or dies immediately on the first try. the second try it starts right up.
Any ideas on what to change to solve this (I know, not much to go on)
Old Oct 25, 2012 | 04:32 PM
  #267
binder's Avatar
binder
Mine idles at 1100. At no point does it ever drop below 1000 rpms and it will start working after a full pull to redline. Hal fixed my firmware and cams work all the time now with no issues.
If it doesn't start then prime pulse time in the cold sections. If it starts and dies then you need to work on the early time cells in the post start enrichment at the cold temps.
Unless you hot wire your widebands to stay on during cranking you will just have to play with it. Hook the haltech up and turn the key on then look at the prime pulse map to see where the cursor is. Then try to start it. If it doesn't start then add some fuel to that cell and try again. I would adjust the cells around it as well. If adding fuel didn't help then try pulling fuel. Trial and error is the best way to find out if you do'nt have widebands on during cranking. Usually in cold it's too lean and in the hot it is too rich so adjust accordingly.
Old Oct 30, 2012 | 03:21 AM
  #268
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Increasing the prime pulse got it able to start at cold temps. Now, it is staring fine, and dying about 5 seconds later. And then starting right back up when I turn the key again, no problems.
So, which way should I be moving the timing in the early time cells, post start enrichment? Advancing, or retarding?
Thanks for the help
Old Oct 30, 2012 | 04:19 AM
  #269
MR RIZK's Avatar
MR RIZK
Dave, What I believe Jeff is saying is increase the fueling in the Fuel > Post Start Enrich table. This table is CTS vs Engine Running Time. Work on the 0-2 second column at the desired temp.
I think you took "time" literally as timing
Old Oct 30, 2012 | 05:38 AM
  #270
binder's Avatar
binder
Thanks for the help
Dave, I would keep working with fuel for the time being. Engine timing is probably ok and the last thing I adjust to help hard starting issues.
As I have selected in blue here. It's in the Post-start enrichment table. Raise the fuel in the 0, 1, and maybe even 5 second areas of the cold temps. Those will help keep it running after it gets the first cylinder fire.
If you know the temp you are going to be at the most (say if you are mostly at 60* and not down at 30* like the map shows) then you can hit F3 while you are within that post start enrichment map and add another line in there so you can adjust 60* individually.
Hope that helps. Feel free to email me directly if you have questions and don't want to wait for a response on here.
Attached Thumbnails Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement-post_start.jpg
Old Oct 30, 2012 | 06:51 AM
  #271
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Ah, yes, I did think you meant timing. Duh. Anyways, thanks for the tips, I will try some more with it, and see how it goes. It's kind of annoying, working on 'cold start' because you can only test each adjustment once a day or so, before waiting until the next day after everything cools off to try again
Old Oct 30, 2012 | 07:24 AM
  #272
binder's Avatar
binder
Ya, exactly why I will never use an ecu or tuning solution without an end user tuning software. I am always making minor changes over time with my map to fine tune it.
Old Oct 30, 2012 | 09:25 AM
  #273
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Completely agree, which is one of the reasons I love the Haltech.
Old Nov 28, 2012 | 03:12 AM
  #274
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Quick update: managed to massage the post start enrichment and the first pulse prime and things are good now. Thanks for the help.
Old Jan 10, 2013 | 10:33 AM
  #275
350z-Na's Avatar
350z-Na
since the new the haltech is replacing the OEm ecu. Will it be able to adapt any DBW throttle body? For example: GM lsX dbw?
Old Jan 10, 2013 | 03:21 PM
  #276
meatbag's Avatar
meatbag
It can but it takes working with Haltech for them to change the settings on the back end of the software. I am having them get a file setup to run a ford style throttle body for my car.
Old Jan 11, 2013 | 07:53 AM
  #277
str8dum1's Avatar
str8dum1
what all needs to be setup? most universal boxes control DBW, so wondering what makes the haltech specific to its TB
Old Jan 11, 2013 | 07:58 AM
  #278
meatbag's Avatar
meatbag
SInce the haltech PNP box is setup specifically for the oem TB they dont give you all the parameters to mess with in the software so you just have to get them to change a couple of things to work with a different TB. If it was a universal box then yes you would just put whatever you need in it to run a specific TB.
Old Jan 11, 2013 | 02:00 PM
  #279
SurraTT's Avatar
SurraTT
Really? thats kinda crappy. It should be able to figure out the parameters with the DBW setup stuff.
Did you actually setup a larger tb on this haltech unit?
Old Jan 11, 2013 | 02:35 PM
  #280
meatbag's Avatar
meatbag
Working on it still. Haltech is just waiting for me to tell them which one im going with and the info that comes along with it. Figuring out something that will work and wont have to cut the hood.
