Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement
Old Jan 11, 2013 | 02:43 PM
  #281
SurraTT's Avatar
SurraTT
Originally Posted by meatbag
Working on it still. Haltech is just waiting for me to tell them which one im going with and the info that comes along with it. Figuring out something that will work and wont have to cut the hood.
wow ok thanks for real info!
i must say im disappointed that its setup that way.
always something!
Old Jan 18, 2013 | 04:02 PM
  #282
ranmas2004's Avatar
ranmas2004
OK I have the Haltech 350z Platinum Pro and a turbo. I'm trying to brake boost but seems the ECU is limiting the opening of the TB if I have my foot on the brake and will not build boost. Is there anyway the Haltech can disable this "feature" of the car so I can brake boost? Is there anything I can do besides going to cable TB?
Old Jan 19, 2013 | 05:58 AM
  #283
meatbag's Avatar
meatbag
Ive been really disapointed with the EVT control. Haltech stated that they never even tested the new box on a revup motor.
Im removing EVT side of things on my car but it sucks for anyone with a revup that wants to keep them.
Old Jan 19, 2013 | 06:01 AM
  #284
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
EVT?
Old Jan 19, 2013 | 08:03 AM
  #285
SurraTT's Avatar
SurraTT
This thread is about the full 350z haltech ecu. there are some threads on brake boosting
thats weird the evt control in the harness unit works just fine. Is it the settings on the new unit? Ill def want working EVT as its good for top end power.
Originally Posted by Dave 90TT
EVT?
Exhaust valve timing..
Old Jan 19, 2013 | 09:14 AM
  #286
meatbag's Avatar
meatbag
Yeah it has all the settings but just doesnt work like the harness one did. I thought it was just my car at first until i tried it a couple other revup cars and they have all been the same. It could be something im doing but I dont see what it is at the moment and Haltech has chose to ignore the problem from what I can tell since i never hear back on questions i ask about the EVT control.
Old Jan 19, 2013 | 01:30 PM
  #287
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Duh. I feel stupid.
So, if you have a rev up with the plug and play haltech, then since the original ECU is no longer there, does that mean your EVT is not controlled at all?
Old Jan 19, 2013 | 01:33 PM
  #288
SurraTT's Avatar
SurraTT
Duh. I feel stupid.
no, the Haltech has EVT control built into it, he is just saying its not good and had issues of some sort.
I dont see how the evt system woudl be messed up, unless the settings are not right.
In exhaust cam settings there is frequency, steady state duty cycle, min duty, max duity, deadband, operating temp.
with the old harness unit those setting are not there at all you just hook up the evt cam sensor and actuator and it runs w.e you got in the ecam map.
Old Jan 19, 2013 | 02:48 PM
  #289
meatbag's Avatar
meatbag
It does control it, it is just very erratic. I have not been able to find settings that work.
Old Jan 19, 2013 | 09:04 PM
  #290
rcdash's Avatar
rcdash
Yes, cut the brake signal going to the stock ecu
Same haltech box tested each time?
Old Jan 20, 2013 | 07:30 AM
  #291
meatbag's Avatar
meatbag
Two boxes with three different cars with stock, JWT S7r and JWT C8r cams.
I thought I had a problem with the magnet retarders in my car so I replaced both banks but it as still erratic. Put my old Vpro/stock ecu combo back in the car and it works perfect.
Old Jan 20, 2013 | 12:18 PM
  #292
350z006's Avatar
350z006
Oh man...I was thinking about switching from Osiris to the Haltech ECU with my Revup setup...maybe not
Old Jan 21, 2013 | 03:21 AM
  #293
MR RIZK's Avatar
MR RIZK
Noticed something similar with my intake timing. When graphing inlet cam angle target vs actual it would oscillate on one bank which caused erratic timing. Replaced the vvt solenoid and problem was resolved.
PS: Noticed u tested on other cars. Therefore my post is probably a waste of space
Old Feb 14, 2013 | 09:15 PM
  #294
_Dolle_'s Avatar
_Dolle_
Anything new about the EVT ?
I'm curious because want to buy a plug-in ecu if it works properly.
Old Mar 25, 2013 | 12:57 PM
  #295
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Thanks for the sales! Keep them coming!
Old Apr 2, 2013 | 01:43 PM
  #296
_Dolle_'s Avatar
_Dolle_
I would have bought one if it worked properly with the EVT
Old Apr 2, 2013 | 02:47 PM
  #297
jerryd87's Avatar
jerryd87
dolle are you talking about exhuast valve timing or something else? the old one controls the exhuast cams so why wouldnt the new one?
Old Apr 2, 2013 | 04:08 PM
  #298
str8dum1's Avatar
str8dum1
meatbag and other have had issues getting the PID correct for the cam controls
Old Apr 2, 2013 | 04:57 PM
  #299
jerryd87's Avatar
jerryd87
ahhhh that explains alot interesting is it the tune or simply the unit though?
Old Apr 3, 2013 | 10:57 AM
  #300
Dynosty's Avatar
Dynosty
In stock!
