G35 Build 2nd Try
Old Mar 24, 2020 | 11:29 PM
  #441
rustyschopshop's Avatar
rustyschopshop
Originally Posted by Conway_160
What harness you talking about?
I could only find OEM harness's
https://www.z1motorsports.com/wiring...ss-p-3189.html
Or are you talking about
https://www.z1motorsports.com/z1-pro...ss-p-5833.html
the 2nd one that z1 makes/sources is the one i was refering to. Installed 1 on my current engine.
Old Mar 25, 2020 | 04:55 AM
  #442
Conway_160's Avatar
Conway_160
I ordered one, now it's down to waiting for it to arrive.
Old Mar 25, 2020 | 05:01 AM
  #443
Conway_160's Avatar
Conway_160
Is the knock heard quite easily?
Originally Posted by bealljk
Listen, Conway ... If you have big chunks of metal after your first oil change, you have bigger problems them a ring of RTV on the lower oil pan! lol!!! Lets hope you dont!
If you need another knock sensor subharness I have 3 of them sitting in a box...also, since it's out, you should wire-in the Uprev listening device. Equivilent to the Plex Knock-Block, ie 'det cans' ... actually pretty cool, you can listen to the engine. When I run my car, especially if I'm planning on running it hard, I have plug headphones in hooked up to mine. Basically listening for knock.
https://uprev.com/documentation/Knoc...n%20Device.pdf
Old Mar 25, 2020 | 07:27 AM
  #444
bealljk's Avatar
bealljk
You cant hear it without an amplifier but yea, you can hear it
Some good audio recordings of knock ...
https://theknockbox.com.au/the-knock...nd-recordings/
Old Mar 25, 2020 | 10:06 AM
  #445
Conway_160's Avatar
Conway_160
That sounds insane. There is no doubt you can hear knock.
Old Mar 25, 2020 | 05:39 PM
  #446
Conway_160's Avatar
Conway_160
Installed the clutch, flywheel, and coolant hard lines tonight.
Was going to put the engine in the engine bay and start working on the headers, BUT car said I love you one more time.
Ordered solid mounts tonight, tomorrow I'll set the engine in the engine bay and start working on the headers and accessories.
Old Mar 25, 2020 | 11:03 PM
  #447
bealljk's Avatar
bealljk
Icar said I love you one more time
just a little kiss on the cheek ... that's all
silver lining ... this happened while the engine was out of the car... you know? a little bright side for you!
Old Mar 26, 2020 | 11:22 AM
  #448
Conway_160's Avatar
Conway_160
Engine is installed. Was working on installing headers, and my header wrap started falling apart. I managed to get the wrap removed from the passenger side header.
Will work on it more tomorrow.
Old Mar 27, 2020 | 04:43 PM
  #449
Conway_160's Avatar
Conway_160
We'll its a good start to the weekend.
Old Mar 27, 2020 | 06:26 PM
  #450
bealljk's Avatar
bealljk
Hell yea!
and it's not even really the weekend! You got tomorrow and sunday, tune on monday!
Old Apr 5, 2020 | 01:48 PM
  #451
Conway_160's Avatar
Conway_160
Blower is disconnected!!
Managed to put 20 miles on the car today.
At first I was super worried, when I went to Walmart this morning when I would get into it a little bit I would see a plume of white smoke from the back of the car.
In my head i'm thinking I've never see this before but last time my rings wasn't gaped for boost. So maybe since they are looser they may smoke a little bit until they are seated.
Leave Walmart and notice no smoke, rev it to about 4K still no smoke SWEET!!! We're all good continue home.
About an hour later I take the car back out to put some miles on it. Clutch has been feeling a little funky but figured the stupid rubber grommet was stuck again so didn't really worry about it. Welp then it happened, slave pulled and Epstein all over the ground.
Called a friend to have him two me back to the house. He got there only to find out he didn't have a tow strap.
Wife and kids got in his truck and I limped her home.
So glad this transmission has awesome sycnro's in 1st-4th. For what ever reason it would grind trying to go into 5th so I just limited myself to 4th and 2500-2700 rpms.
I'll get another slave tomorrow, along with conventional oil and break in additive for the next 100 miles or so.
How long are/can you run mineral break in oil? I have 20 miles.
Old Apr 5, 2020 | 02:11 PM
  #452
bealljk's Avatar
bealljk
Good to hear its up and running!
are you sure it's the slave cylinder?
This is your first ever oil in this engine? If so I wouldnt put no more than 50miles on it... you're gonna have a bunch of gunk and other stuff floatin in that oil that you want to flush out before not too long...then I might put a fresh conventional oil in it for another 500miles to 1000miles and then go full syn...just my two cents
Old Apr 5, 2020 | 05:25 PM
  #453
Conway_160's Avatar
Conway_160
This is your first ever oil in this engine? If so I wouldnt put more than 50miles on it... you're gonna have a bunch of gunk and other stuff floatin in that oil that you want to flush out before not too long...then I might put a fresh conventional oil in it for another 500miles to 1000miles and then go full syn...just my two cents
Yea, it exploded. The inner rod that pushes on throw out bearing thing was sticking out the side of the rubber when I got under the car.
I will change the oil tomorrow with 10-30 and Zinc additive.
Old Apr 6, 2020 | 09:13 AM
  #454
GreyZ's Avatar
GreyZ
That sounds like you have the pedal stop misadjusted, allowing the master to travel far enough that it over travels the slave and pushes the rod completely out. I would recommend adjusting your lower pedal stop so that it does not happen with the new one on the first hard shift.
Old Apr 6, 2020 | 10:59 AM
  #455
Conway_160's Avatar
Conway_160
I'll try that, but as it stands my clutch doesn't even engage until about 1/2" into the throw.
Old Apr 6, 2020 | 11:33 AM
  #456
OldManZ350's Avatar
OldManZ350
Run the Motor for 20 mins, then Change the Oil & Filter. ( You want to get any Crap out that might be in the motor ASAP )
Put in Regular Conventional Oil and change at 300-500 mile Max. Motor is Now broken In!
TimRod
Old Apr 6, 2020 | 01:10 PM
  #457
Conway_160's Avatar
Conway_160
TimRod
Thank you sir!
Old Apr 10, 2020 | 05:08 PM
  #458
Conway_160's Avatar
Conway_160
Up to 50 miles on the car. I will say that even though I'm limiting my right foot to about 3500 rpms if I'm not careful the car will hit 3psi. I have yet to hit more than 25-30% throttle.
Old Apr 10, 2020 | 05:32 PM
  #459
OldManZ350's Avatar
OldManZ350
You want to very the LOAD and RPM to seat the Rings.
You're Fine.
More and More Load & RPM with time.
Old Apr 10, 2020 | 06:05 PM
  #460
bealljk's Avatar
bealljk
You're Fine.
I whole-heartily agree ... vary load and vary RPM ... stay away from either (low or high) rpm extreme ...
