FAQ: Official wheel "SPACER" thread!
Old Jul 29, 2010 | 08:03 PM
  #401
pizzato16's Avatar
pizzato16
I know youre not asking me, but I dont think you will have a problem with rubbing on nismo suspension with 20mm spacers.
Old Jul 30, 2010 | 04:00 AM
  #402
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by pizzato16
I just bought some 5mm for my rear. After reading *Ice*'s issues with loosening nuts, im kinda worried if this is a common thing or was it because of lugs not being torqued enough. Ive heard of a few people run these with no problems, but one problem is just the same.
So long as they are machined units and torque'd properly they should be fine.....
He never responded if he "marked" his studs to see if they spin in the hub. Ie, the knurl is bad and stud is moving??
If he ever over torqued them too much "one" time he could have galled/fractured the threads at the stop point of engagement and now the threads wont hold torque.........like he said, if it keeps happening after careful monitoring, then the next thing to do is swap the studs...
if 5mm(spacers in general) is what you want, go for it, but like anything else on your car, it requires a "degree" of maintenance.......
-J
Old Jul 30, 2010 | 04:02 AM
  #403
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by nismomike
Jason, I am running wider tires on my stock 08 nismo. Tires are 265/40/18 front and 285/35 rear ( Up from 245/265 respectively.)I am on stock Nismo suspension and don't plan on lowering it. What should I run, do you think, to make the wheels relatively flush? I was thinking 20 mm all around? Would I need to roll the fenders with that wide of a tire? Thanks Jason!
I agree with Pizza, i doubt it, but the best thing you can do is measure....
Measure tire to fender:
1. Sitting there, normal state
2. while re-creating a bump by driving on top of one board
3. while re-creating a bump by driving on top of two boards
from there, decide what thickness spacer works best.....
-J
Old Jul 30, 2010 | 01:32 PM
  #404
pizzato16's Avatar
pizzato16
^ what a great idea.
These are the spacers I bought that were recommended to me another fellow z owner. Any qualms about these?
http://cgi.ebay.com/ebaymotors/ws/eB...m=290458606502
Old Jul 30, 2010 | 01:33 PM
  #405
nismomike's Avatar
nismomike
-J
Pizza and Jason, thanks so much for the advice. Will try to recreate it and go with whatever I feel comfortable with and will post pics of the end result!
Old Jul 30, 2010 | 03:07 PM
  #406
JasonZ-YA's Avatar
JasonZ-YA
do not buy those!! cheap cast, universal pitch.....
go back and look at those i linked for 5mm..
-J
Old Jul 30, 2010 | 03:15 PM
  #407
JasonZ-YA's Avatar
JasonZ-YA
Old Aug 4, 2010 | 06:31 PM
  #408
bswanny's Avatar
bswanny
I looked over this thread and was wondering, are there any instructions on how to take off / what to take off in order to install the extended studs onto the hub?
Old Aug 5, 2010 | 03:17 AM
  #409
JasonZ-YA's Avatar
JasonZ-YA
Hummmm????
Post #10:
https://my350z.com/forum/7149652-post10.html
-J
Old Aug 5, 2010 | 03:03 PM
  #410
bswanny's Avatar
bswanny
Yeah but that shows the rotor aready off. I want to know if you are just taking the caliper bracket off to get to the rotor of if it is more involved. I know how to press studs out.
Old Aug 5, 2010 | 07:30 PM
  #411
JasonZ-YA's Avatar
JasonZ-YA
^ ya, to get to that point, its no biggy, remove the caliper bolts and hang the caliper out of the way and then remove the rotor......easy breezy...
From there use one of the options listed on that post #10.
I know that the rear, you have to spin the hub to the back and the bolt has room to come out.........but its pretty straight forward task.
if you do the hammer method to remove and dont have a heavy enough hammer then it can take you a while, etc.
-J
Old Aug 6, 2010 | 09:14 AM
  #412
bswanny's Avatar
bswanny
-J
Thank you, that is what I wanted to confirm. Are there any pics of this?
Old Aug 6, 2010 | 09:34 AM
  #413
JasonZ-YA's Avatar
JasonZ-YA
the best pics are what 3-5-0 shows on option 3 on post #10
-J
Old Aug 8, 2010 | 07:31 AM
  #414
350Z_Al's Avatar
350Z_Al
Finally got some half decent pics:
R :19x9.5 +10 (after 15mm spacer) 285/35/19
A couple more recent pics of mine:
Old Aug 8, 2010 | 07:48 AM
  #415
angelo350z's Avatar
angelo350z
HOT!!
Old Aug 16, 2010 | 09:00 AM
  #416
BoomerZ33's Avatar
BoomerZ33
not bad dude not bad. you have spacers up front too?
Old Aug 16, 2010 | 07:17 PM
  #417
350Z_Al's Avatar
350Z_Al
Not yet, I need to do either a 20mm or 25mm up front. Which will result in 8.5 with a 0 or -5 offset.
It's on my To-Do list, but closer to the bottom now, I've been concentrating more on parts for my Vortech install, and paying for school
Old Aug 20, 2010 | 10:34 AM
  #418
doeboy711's Avatar
doeboy711
Here are my pic sof my wheel spacers. I have 25mm all around. I am trying to sell my rear set of spacers to buy 30mm in the rear to make it more flush. What do you think of it?
PM me if ya want a set of spacers as well
Old Aug 23, 2010 | 06:22 PM
  #419
billas 350z's Avatar
billas 350z
Anybody want to trade with my ichiba VII 25mm spacers for the same brand but 20mm's? lMK.
Old Aug 24, 2010 | 04:33 AM
  #420
JasonZ-YA's Avatar
JasonZ-YA
post a WTB, WTT thread..........it will happen fast..
-J
