Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Jan 4, 2012 | 04:22 PM
  #461
Cass007's Avatar
Cass007
Brew... still wanting to see if you have any info on the AC lines.
Old Jan 4, 2012 | 04:29 PM
  #462
bbs350z's Avatar
bbs350z
+1^ need these suckers bad before the heat kicks in and the manglands get moist
Old Jan 22, 2012 | 07:14 PM
  #463
ducky's Avatar
ducky
This is a very informational thread. Thanks for all the contributed info.So just a recap and some questions. I have been eyeing this swap and researching since I bought my G last year. Now it seems the t56 tranny is the tranny of choice..my question is how strong can these be made to handle boost compared to a built auto 4l80e. Also fd on the stock rear is 3.5, BBS once he tries his lower fd I wonder how it would drive with boost...I am on the verge of using a 3.3/3.2 FD with boost setup.I think the 3.2 would be sweet...of course it would need to be a custom gear. How are you guys doing with the auto 3.3 swap?
Wiring wise, Chasebays is hands down the choice for simplicity and sanity... Logan is using the Computech dash and wonder if they can utilize the AIM MXL dash instead. This choice is more of a want since I would like a clean look instead of having multiple gauges when going boost.
I am sure as we are evolving with this swap, rear end will be the key. I can see the monstrous V8 tearing out the rear end, so planning to do reinforcement to keep it together and planted when dragging but still enjoy it on the street...I've read someone had already tore the rear end.
Anyhow, not really a post of information but just brainstorming and thanking everyone for this informational thread once again.
Old Jan 23, 2012 | 10:58 AM
  #464
10-E-C-350Z's Avatar
10-E-C-350Z
Oh god i just checked in to see all the updatea. One more week and im back home. Then i start buying things
Old Jan 23, 2012 | 12:06 PM
  #465
bbs350z's Avatar
bbs350z
^you'll probably finish before me too lmao.
gotta switch everything from my currently built ls1 to a new iron block, my ls block has a crack and hairline fractures along the starter mount which constantly sees torque from the starter so im not chancing it. and i gotta make a fat skidplate for the turbalurb
Old Jan 23, 2012 | 12:59 PM
  #466
Brew_haha's Avatar
Brew_haha
our harness is a stand alone harness and can be adapted to any gauges, we also have power steering kits with remote reservoirs and fuel line kits and radiators and radiator line kits if you dont want to use your stock stuff.
D- tryin to be iron man like me now eh
Old Jan 23, 2012 | 01:08 PM
  #467
Brew_haha's Avatar
Brew_haha
In the nicest way possible i wont be releasing my AC line info because the lines are about to be put in production for us. For either location. Top mount and bottom mount style compressors. The kit will also have a optional slim condensor to fit with our tucked radiator.
Old Jan 23, 2012 | 06:00 PM
  #468
ducky's Avatar
ducky
The iron block is the best route to go if you dont want to sleeve..I dont mind the extra weight...I lost 75lbs the past 7 months to compensate lol LQ9 ftw!!!
I was browsing your products and hands down, great craftsmanship.
Smart move, it's the details that counts..., hence me supporting your company in the near future.
As for the lines I was a bit worried, I did find a local shop/company who can do the lines for me as well...pretty much any kind of high pressure (hydraulic) lines that can do...but the tandem of having the tucked radiator and slim condensor is appetizing.
Old Jan 23, 2012 | 06:51 PM
  #469
Rambo's Avatar
Rambo
I have been reading this forum for a while and have not heard much about a tucked radiator. What is this? May want this for my build.
EDIT: OK looked it up. Sounds cool. What does it sacrifice? Just be cause it pases the coolant twice, how do you know you are still getting cool air and not heat soaked from the first pass? This is me just thinking outloud so please clarify.
Thanks,
Old Jan 23, 2012 | 09:22 PM
  #470
bbs350z's Avatar
bbs350z
lol you know it! psh 100 bucks for a block, figured why not give it a shot. just gotta bore everything out to ls1 specs, deck the head, etc and shes ready to roll again lol. i dont think tx2k12 is happening, but zdayz, im there
Old Jan 25, 2012 | 11:11 AM
  #471
Brew_haha's Avatar
Brew_haha
Thanks,
A double-pass radiator allows for a more efficient cooling system utilizing the same given core area and air flow by first passing the coolant over the top half of the radiator and then the bottom half in the opposite direction, allowing the radiator to dissipate heat twice from the coolant. You dont sacrifice anything. We make them with OE outlets or -16AN fittings.
Old Feb 1, 2012 | 01:58 PM
  #472
Skrilla's Avatar
Skrilla
Originally Posted by QTB
If I were to do it again. I would buy a bare block and build from there to match your goals. Given you want 550 rwhp you'll either need some RPMs or more displacment, either will require a built bottom end. You can get L92 heads with flow enough for 600+HP for about $500 but you'll probably want them ported if you are shooting for 550 at the wheels. If money is no object Lingenfelter heads are pretty sweet. I went to Flow Tech Induction to get a custom speced cam and valve train, Ed Curtis will hook you up!
If you're going to use the Sikky shifter you'll need the GTO T56, or you'll have to swap out the rear housing of the transmission to get it all lined up. I personally think the GTO is the worst geared T56 of them all so for me that was a deal breaker, hence my route of the Magnum, which is also a PITA.
You'll probably want the GTO type accesory configuration so the alternator is down low vs I have a Vett config and the alt. is up high right in the damn way of everything. Then get a custom wiring harness and source a PCM or go stand alone, again which ever suites your needs best. GM sells nice LS harnesses with everything you need but there are lots of options here. You'll also need to either convert to a cable throttle or use a DBW, in which case you'll need to get the pedal assembly as well, also GM can hook you up here too.
The worst part about doing a bare block is getting all the accessories but you'll have everything exactly how you want. It's probably about a wash in the end on price differences of buying a pull out motor and trans vs just building from the ground up, but I haven't run the numbers.....it scares me
That's my $0.02
Tell me about that tranny are the gears too short/weak?
Old Feb 1, 2012 | 04:48 PM
  #473
bbs350z's Avatar
bbs350z
gearing is too short i beleive. im running a built camaro trans which has longer gears and carried over the 3.3 rear end from my last build. my gears are long and great for boosting
Old Feb 1, 2012 | 05:58 PM
  #474
ducky's Avatar
ducky
where did you get your trans built and how much power/tq can it take?
Im up on the fence with a built t56 tranny or 4L80e
Old Feb 1, 2012 | 07:10 PM
  #475
bbs350z's Avatar
bbs350z
bough it off a guy from indiana, built by a local shop. the gears themselves are strong, theres just upgraded parts in the trans. iirc it can hold around 1000+ he was making 850+ without a hiccup. had it for 1k miles and swapped to an auto. check out the t56 magnums or tr6060, but youd need a custom drveshaft as they are a bit longer i believe
Old Feb 1, 2012 | 10:45 PM
  #476
QTB's Avatar
QTB
There are a few places you can get a built T56, and even more they'll usually have a option of gears to choose from. The main one that comes to mind is D&D transmission and RS gear.
If money isn't an issue here's the route I would have gone: http://www.rsgear.com/products/trans...tranzilla.aspx
and I'd probably go with either one of the bottom two gear sets they have listed depending on power goals and usage.
Old Feb 1, 2012 | 10:56 PM
  #477
QTB's Avatar
QTB
I'm doing a Magnum and let me tell you it's far more than a shorter driveshaft. Major PITA!
Old Feb 1, 2012 | 11:14 PM
  #478
ducky's Avatar
ducky
good info, thanks!!!....I'm going turbo.I just need to solidify my plans, now time to see how much this tranzilla tranny costs.
Also just to note fueled performance will make any driveshaft you need to whatever tranny you want to to run.
Old Feb 2, 2012 | 02:47 AM
  #479
QTB's Avatar
QTB
Yeah the big issue with the Magnum is the shifter. it uses a 6 bolt design vs the regular T56 has 4 bolts. It's requires about a 9" offset to hit the OEM shifter position. The drive shaft needs to be about 2" shorter and uses a 31 spline shaft, I'm using a Ford C6 yoke to make it all fit. Which is do-able but it gets spendy. By the time i shoe horn this thing in i could have just gotten the Tranzilla or at least been close. But I'm determined to make it work.
Old Feb 2, 2012 | 05:48 AM
  #480
Skrilla's Avatar
Skrilla
Thanks for the quick response you gave a lot of info here. Thx QTB for what you said on "if you were to do it over"
hmmm, well I pulled the trigger and decided to go the LS route, but I prefer NA for now. So much info on these pages but there are a couple questions. This will be my daily driver
some quick questions for anyone game to answer
1. would stock T56 work for 500-550whp? I'm asking because of its supposed ease for this swap. thinking about GTO LS2 engine/tranny drop out.
2. Anybody running PCM and Z ECU for emmissions/smog purposes? seems feasible although a little antiquated
3. how much of the stock accessories can be retained, such as AC, PS, ABS
EDIT: 4. is there a difference between a "magnum" T56 and "regular" T56 - again most likely coming from ls2 vette or GTO
haven't seen a swap yet with the last 2 questions here or I probably just missed it
you guys are some mother****ing trailblazers
