vortech FAQ: read this before asking vortech questions
Old Oct 9, 2007 | 12:23 AM
  #121
sentry65's Avatar
sentry65
the burninator
yeah if you change a few things I think - the piping is a little different
Old Oct 9, 2007 | 05:39 AM
  #122
Barzten1's Avatar
Barzten1
For any of you Vortech owners who wonder about the 2.87 pulley, its amazing. Make sure you have a solid tune to go with it and you should be ok. Wish I would have done this a year ago.
Old Oct 9, 2007 | 05:46 AM
  #123
Cux350z's Avatar
Cux350z
hatersgonnahate
^need to update your sig
want to sell the 3.12 pulley?
Old Oct 9, 2007 | 06:22 AM
  #124
Barzten1's Avatar
Barzten1
Ooohh I forgot. I want to keep the pulley but thanks.
Old Oct 9, 2007 | 06:24 AM
  #125
Cux350z's Avatar
Cux350z
hatersgonnahate
ah no prob.
what tq spec did you use on the pulley bolts? did you use loctite?
Old Oct 9, 2007 | 06:31 AM
  #126
Barzten1's Avatar
Barzten1
350zDCalb installed it for me. Not sure on the specs
Old Oct 15, 2007 | 07:50 AM
  #127
dikspiel's Avatar
dikspiel
Chestons Toilet
gr8 writeup
Old Nov 1, 2007 | 11:58 AM
  #128
gothchick's Avatar
gothchick
Yeah, one of the best write ups & discussions I've read. Thanks guys! :-)
Old Nov 1, 2007 | 03:38 PM
  #129
G35asian's Avatar
G35asian
Do you have a built motor?
Old Nov 20, 2007 | 07:22 AM
  #130
jonnylaw's Avatar
jonnylaw
so I understand that an underdriven pulley should not be used cuz it would result in less boost, but is the stock pulley really the best crank pulley to use?
I have currently installed a UR stock size lightweight crank pulley-would this be ok with a sc, or problematic due to the lighter weight?
What about dampened pulleys like the ATI and Fluidampr? Those are slightly overdriven and should result in higher boost in addition to lessening torsional vibrations. Thoughts?
Old Nov 20, 2007 | 09:22 AM
  #131
sentry65's Avatar
sentry65
the burninator
that subject is a whole can of worms in itself
Old Nov 20, 2007 | 12:03 PM
  #132
jonnylaw's Avatar
jonnylaw
so does that mean that you are using the stock crank pulley?
Old Nov 20, 2007 | 12:56 PM
  #133
sentry65's Avatar
sentry65
the burninator
I'm running a lightweight crank pulley, but I think most people run the stock pulley.
There's risks with running a lighter pulley and the people that have ran into issues with them will tell you it's not worth the risk
On an expensive built engine, I'd probably not run a light crank pulley
Old Nov 20, 2007 | 01:16 PM
  #134
jonnylaw's Avatar
jonnylaw
ok thanks sentry. Gr8t writeup btw
Old Nov 20, 2007 | 01:18 PM
  #135
Cux350z's Avatar
Cux350z
hatersgonnahate
did you guys know we have weaksauce setups? Taurran told me, so it must be true. Truth hurts
Old Nov 20, 2007 | 04:36 PM
  #136
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
... please keep the drama from other threads out of here... just let it go
Old Nov 24, 2007 | 01:55 PM
  #137
xav_350z's Avatar
xav_350z
guys whats the stock crank pulley diameter ? any idea?
Old Nov 25, 2007 | 06:33 AM
  #138
fishclub's Avatar
fishclub
Hi,
This is what i have in hand now:
RC 440cc injetors off from the Greddy TT kit (in my garage)
Walbro fuel pump(in my garage)
Utech(in my garage)
Vortech tuner kit(on the way)
DC headers (on the car already)
Kinetix V+ and high flow cat(on the car already)
Injen SES (on the car already)
Will this set up give me 400whp safely? Or anything i should add to the setup? Please help, I am new to the supercharge world?
Many Thanks!!
Ka
Old Nov 26, 2007 | 03:33 PM
  #139
sentry65's Avatar
sentry65
the burninator
I answered your PM fishclub the other day that you might need to either get larger injectors OR get a return fuel system, but I don't think 440cc's will be enough with just those and a walbro.
as far as power you might reach, I also added this to my #17 post in this thread. People can try go see what range of whp they might end up possibly getting
- ballpark hp numbers for original VQ35 on a typical dynojet SAE corrected generally are in the neighborhood of:
320-335 whp, stock vortech tune with stock pulley and stock everything else on car (stock exhaust, cats, etc)
340-350 whp tuned
350-370 whp add exhaust, HF cats, plenum, and tuning
370-390 whp add 3.12 pulley and tuning
380-400 whp add headers and/or test pipes, and tuning
390-420 whp add 2.87 pulley and tuning
420-440 whp add cams and tuning
440-475 whp add water/meth injection, more timing, at least half race gas (96 octane or higher) and tuned
470-500 whp add 34 tooth rear cog jackshaft pulley and tuning *theoretical
500-580 whp upgrade blower, build engine with 4.24 liter stroker kit, ported heads, and keep compression ratio somewhat high around 9.5 or so,
torque numbers are generally 70-90 less than the peak whp numbers
Old Nov 27, 2007 | 02:32 PM
  #140
Bahraini350Z's Avatar
Bahraini350Z
do u need to buy a belt with the change to a 34 cog?
