Official STS Rear Mount Turbo Discussion Thread
Old Oct 25, 2011 | 07:33 AM
  #2661
n2deepnot2keep's Avatar
n2deepnot2keep
Originally Posted by str8dum1
how did you get a lack of oil? even if the pump failed, the turbo would overflow with oil but woudnt be enough to drain your motor of oil. And if the seal on the turbo actually went, your car woulda been smoking like a forest fire well before your oil pressure went low enough to kill the engine.
anyone that has to use a oil sump pump is absolutely crazy not to have an oil pressure gauge.
Don't know, ask Kyle at ipp. He told me ha has only warranted 1 engine in the 6 years he has been building them.
That tells me he just don't honor warranties.
Old Oct 25, 2011 | 08:27 AM
  #2662
str8dum1's Avatar
str8dum1
what was the final failure? spun bearing?
Old Oct 25, 2011 | 05:51 PM
  #2663
n2deepnot2keep
The engine wasn't a complete loss, I learned from my first build to shut it down right away.
The bearings were in pretty bad shape but not spun.
They could have saved the crank but I got that replaced just so I don't have it to worry about.
The heads and cylinders were a little scraped up from the trash in the oil but were conditioned just fine.
BTW started out with a gt35 and it blew a seal. My tuner then got a precision 6562 and he then blew out that seal too, this time the alarm went off for the oil pump. This is when my tuner figure out what was the cause of the turbo failers. I guess the pump was failing for a while but not enough to trip the 1 psi alarm.
So any way I had the seal repressed, then I got an exa pump put on took the car that night with a conservative 8lb boost tune and not long after that I felt a grinding sensation when I gave it throttle in 4th, first thing I did was look at my oil pressure and it was good till I took my foot off the gas.
At idol it didn't have hardly any pressure at all.
Old Oct 26, 2011 | 06:40 AM
  #2664
str8dum1's Avatar
str8dum1
sorry to hear that
if you were dropping to 0 oil pressure at idle, i guess all your oil was dumping out into your exhaust?
what a mess!
Old Oct 26, 2011 | 06:10 PM
  #2665
rawley_12003's Avatar
rawley_12003
Unhappy
Originally Posted by n2deepnot2keep
I had an ipp engine on a sts kit and my engine failed due to lack of oil this is after replacing the p.o.s Chinese built pump with a example pump. I saw the pump working when it was tested with my own eyes.
My engine went the same day I picked it up.
Kyle did not warranty the engine nor did he refund my core charge from my original engine.
Don't expect your $ back if if engine goes bang.
Good luck with your build, I'm going with the momentum kit now.
Oh well hopefully i don't run into the same issues so
Old Oct 27, 2011 | 05:44 AM
  #2666
Fluid1's Avatar
Fluid1
Originally Posted by rawley_12003
i did have at one time but i think all i was running where 13.6 all night at 309whp.
Ouch I was .1 slower than that bone stock in an 03
I'm looking at a STS twin rear mount setup for the LQ9
Old Oct 27, 2011 | 02:26 PM
  #2667
rawley_12003
Oh just to give you you a heads up this was the day after i got it back so definitely was getting use to the setup it was my 60 ft i need to work on but need to get a launch control setup on it but not sure if it will work on a base though i need it to build a little bit of boost at least to get off the the line faster and maybe some d/r's.
Old Oct 27, 2011 | 05:18 PM
  #2668
str8dum1's Avatar
str8dum1
twin STS is alot of piping, just go with a PTE Pro Mod91. Thats what all the big boys are using With that much displacement, it will have a good powerband
Old Oct 27, 2011 | 05:22 PM
  #2669
Fluid1's Avatar
Fluid1
I wasn't trying to talk trash on you bro. FWIW I only ever drag raced that Z I was referring to the one night.
str8dum1, I'm leaning towards a precision turbo, .76mm bb
The LQ9 is "only" 6.0l heh
Old Oct 27, 2011 | 05:58 PM
  #2670
rawley_12003
Talking
Oh i wasn't mad just explaining myself lol.. no problem
Old Oct 28, 2011 | 06:50 AM
  #2671
str8dum1's Avatar
str8dum1
76 is too small (unless you mean 2). they use 76mm on 3 - 3.4L supras. even Snyper said that 88mm felt too small and had little lag.
You have a long road ahead in your build, but I'd seriously look at compressor maps. you'll be surprised how much turbo you can really and get a great powerband. 6L is a lot of displacement.
Old Oct 28, 2011 | 08:16 AM
  #2672
Fluid1's Avatar
Fluid1
Strange, I've seen the 76 push nearly 1200
But the actual turbo part is going to be last, I didn't order anything turbo related yet. Just want to get the long block build and in our possession
[/threadjack sorry guys]
Old Nov 14, 2011 | 06:35 PM
  #2673
rawley_12003
Has anybody done anything new with their g or z?
Old Nov 17, 2011 | 06:52 PM
  #2674
John1006's Avatar
John1006
Ok I'm about to start my build. My goal is 500whp with a rear mount. I'm trying to buy a block and crank from a member on here if he'll ever get me a shipping quote. Obviously forged bottom end is needed, but everywhere I look i get some mixed reviews on the DE heads. Would 500whp be alright with the stock DE heads? Also hoping you guys could help me out on which turbo to get. I'm knowledgeable in just about every aspect of building motors, but I've only had 2 other boosted cars one was a twin turbo VR4, had stock turbos. The other was a 300zx TT upgraded turbos but I didn't choose the turbos. So my question is can someone help me decide on a turbo to buy. Just seems like theres a million options out there. Thanks in advance.
Old Nov 20, 2011 | 06:16 PM
  #2675
rawley_12003
nice, I'm like 2 hours from you i live in wichita,ks. I have a sts kit engine being built right now.
Old Nov 20, 2011 | 08:02 PM
  #2676
John1006's Avatar
John1006
Only about hour and a half. I've been to wichita several times to pick up cars and parts and what not.
Old Nov 21, 2011 | 02:47 PM
  #2677
rawley_12003
oh ok cool
Old Nov 24, 2011 | 05:17 AM
  #2678
jsrodz's Avatar
jsrodz
Originally Posted by goosegoose
I have the manual in PDF. PM me your email address.
Hi,
I red that you have the sts manual on PDF. I bought a used sts kit that came without it.
Please send it to jsrodz@gmail.com
Thanks for your help
Jesus
Old Nov 28, 2011 | 03:00 PM
  #2679
rawley_12003
huh well i just had to purchase a new oem oil cooler for the engine other one have metal chunks in it that couldn't get out.
Old Nov 29, 2011 | 06:07 PM
  #2680
rawley_12003
is there any reason to upgrade my oil pump from the one that sts supplies the kit if my goal is around 450 whp?
