Another built motor Vortech dreamer thread.
Old Feb 5, 2015 | 05:54 PM
  #341
OldManZ350's Avatar
OldManZ350
https://my350z.com/forum/shop-builds...ml#post9564567
Start with post 136
And Ya, Classy here is a pic of your post about making the plate stronger.
Attached Thumbnails Another built motor Vortech dreamer thread.-screen-shot-2015-02-05-at-9.50.03-pm.png
Old Feb 5, 2015 | 10:54 PM
  #342
Resmarted's Avatar
Resmarted
It's hard to tell because the car jerks forward on the dyno. But it could be flexing. If I were you I'd get the carbonite pulley coating. That's the most guaranteed way to increase friction on your pulley.
Old Feb 6, 2015 | 03:16 AM
  #343
Classy's Avatar
Classy
Start with post 136
I was not nearly as well informed then (3 years ago) than I am now.
I think alot of your posts oldman have been EXTREMELY biased towards people buying your radius rod, good bad ugly, it doesn't matter, you are kinda forcing it down people's throats. Vendors in my experience who do that generally are kinda shady.
Old Feb 6, 2015 | 03:17 AM
  #344
Classy's Avatar
Classy
I have heard of success with that and IF you were to go down this road, I think investing in a 8 rib setup at the same time would do you well.
Old Feb 6, 2015 | 08:32 AM
  #345
str8dum1's Avatar
str8dum1
Thats a great customer service. Either it works or you can return it. No reason not to try it.
Originally Posted by meanz
If your that confident that it is flex, I'll take your strut. If I don't see an increase in boost, I'll send it back.. Really don't want to throw more money around I don't have.
Old Feb 6, 2015 | 01:40 PM
  #346
OldManZ350's Avatar
OldManZ350
If that's how I come across, then I'm Wrong!
I'm not a vendor, I'm just one of you guys........
All I have wanted to do here is help people, and I've done a fair amount of that in the last 12 years.
Old Feb 6, 2015 | 01:44 PM
  #347
OldManZ350's Avatar
OldManZ350
A 8 or 10 Rib Custom Pulley Set up is the way to if you have $3000+ to spend on it. A 10 Rib is the only way I would go with an 800whp+ Blown Z or G Car.
Old Feb 6, 2015 | 02:06 PM
  #348
Resmarted's Avatar
Resmarted
I'm about to look into the cost of a 10 rib setup. If you have an ATI Damper already, I can't see how it would cost much more than $400 for a new outer shell. Then a 10 rib vortech pulley is an off the shelf item... Less than $200 for it. The "hardest part" would have to be figuring out the pulleys for PS and idlers...
OR if you have an ATI super damp, and you have a custom outer made, you could have them put the 10 rib or 8 rib on-top of the stock 6, with a wall between them. There's barely room for it, but I think it would fit. Nothing slim radiator fans wouldn't fix (which are relatively cheap). Then you could just extend out the vortech 10 rib pulley and have a direct drive. Add in a couple of idler pulleys and figure out a way to tension it, and you're done.
Would it be an overnight job? Probably not, but the fact everything mounts to a basic plate means you can do just about anything you want...
Old Feb 6, 2015 | 02:31 PM
  #349
str8dum1's Avatar
str8dum1
at that point, you'd just be doing it to say you had a supercharger. The parasitic loss is soo high at that point. add nitrous if you want more power at that point.
Old Feb 6, 2015 | 02:46 PM
  #350
OldManZ350's Avatar
OldManZ350
Hummmmmm!
Should I say 2500-4000 Horse Power with some cars.....
None of these guys seam to concerned about parasitic loss.
Attached Thumbnails Another built motor Vortech dreamer thread.-306720_10151055439795255_921701333_n.jpg   Another built motor Vortech dreamer thread.-p8260003.jpg   Another built motor Vortech dreamer thread.-20140823_184359_zps0a150e12.jpg
Old Feb 6, 2015 | 03:23 PM
  #351
str8dum1's Avatar
str8dum1
dang what year 350z or G35 are those? because I am sure that we are taking about VQ35's
Old Feb 6, 2015 | 03:24 PM
  #352
Classy's Avatar
Classy
Those are gear driven, like the murder nova was
Old Feb 6, 2015 | 03:46 PM
  #353
OldManZ350's Avatar
OldManZ350
So...... You want Belt Driven!
Attached Thumbnails Another built motor Vortech dreamer thread.-rpmmagazinephotoshoot1-27-09002.jpg   Another built motor Vortech dreamer thread.-1.jpg   Another built motor Vortech dreamer thread.-jpfwork026.jpg   Another built motor Vortech dreamer thread.-picsofcars2008033.jpg   Another built motor Vortech dreamer thread.-100_1548.jpg
Old Feb 6, 2015 | 03:48 PM
  #354
OldManZ350's Avatar
OldManZ350
Oh Look!
What is that mounted to the shock tower and Blower?
Could that be a Radius Rod?
Old Feb 6, 2015 | 03:55 PM
  #355
OldManZ350's Avatar
OldManZ350
I'm talking about Cars and Blowers.
The Blower does not know what kind of motor it's on. The Laws of Physics apply to the Whole Universe. A VQ motor is not exempt.....
What Phucking Planet are you on?
Old Feb 6, 2015 | 05:18 PM
  #356
OldManZ350's Avatar
OldManZ350
https://my350z.com/forum/forced-indu...00whp-z33.html
read post 15
Old Feb 7, 2015 | 05:24 AM
  #357
meanz's Avatar
meanz
Been trying to catch up on some sleep. 830 mile round trip in a z will tire you out! I pulled my belt off and side by side to my new belt, the old belt is a little bit longer. I ordered the same belt, so I guess it stretched a good bit. I had to lower the tensioner all the down to get it on. Moved an idler pulley and shredded the belt first pull. Put the old back on and see consistent 22psi right at 6900-7k. I'll record a log to be exact. I might be missing 1-2 psi up top, but not that worried about it at the moment. Spent to much money on this trip, lol. I brought bigger 1300ID injectors with me just incase, but they weren't needed. Glad I can return them! 1100$ back into the account. Z is pulling hard up top. I'll try to up load the graph later after work so you guys can see.
Old Feb 7, 2015 | 05:57 AM
  #358
Resmarted's Avatar
Resmarted
Yeah sounds like you had that belt tightened down rediculously... Which is obviously how you got those numbers hahaha. A carbonite pulley coating should be under 100$ shipped back to you... Definitely worth looking at. It may be possible to switch to a cheaper belt too afterwards.
Old Feb 7, 2015 | 11:17 AM
  #359
meanz's Avatar
meanz
Old man check your notifications
Old Feb 8, 2015 | 01:30 PM
  #360
meanz's Avatar
meanz
Here is a picture of the upper end of the graph. Note that my boost line is still slightly going up, I can literally lay a straight line on it and it pretty much matches up all the way across. My hp is now flattening out though. If my boost is still going up, should my hp still climp also. Maybe the hp flattening out is a small amount of slip? Or maybe this blower is out of steam already?
