FAQ: Official wheel "SPACER" thread!
Old Jun 3, 2010 | 06:42 AM
  #361
HXS's Avatar
HXS
^ thanks J...
well, when i had the mechanic install these, he didn't check that they were the same length... he installed them anyway oh well what can u do...
Old Jun 6, 2010 | 02:19 PM
  #362
HXS's Avatar
HXS
just fyi, i found out that my front oem studs are LONGER than my rear oem ones lol.
fronts on the left are 35-mm threaded (47-mm overall) and rears on the right are 30-mm threaded (42-mm overall). they came from my 2004 G35 coupe.
so to beat a dead horse, i guess running up to a 5-mm spacer up front would be ok.
Old Jun 6, 2010 | 07:40 PM
  #363
JasonZ-YA's Avatar
JasonZ-YA
^^ Great info..............
I wouldnt claim that 5mm is 'only' okay for fronts........the rotor hat in rear is skinnier at the lug holes...so engagement is the same dispite the shorter length in rear ...
Im gonna copy/past this info to the post on the first page....for more exposure..
-J
Old Jun 6, 2010 | 07:45 PM
  #364
HXS's Avatar
HXS
btw, i found high-quality fairly inexpensive almost hub-centric 3-mm and 5-mm wheel spacers HERE.
these were made for mitsu 3000gt and dodge stealth, which have 67.1 mm center bore... ours is 66.1 mm.
i got sets of both 3 and 5-mm and that 1 extra mm is NOT a big difference AT ALL.
Old Jun 7, 2010 | 10:23 AM
  #365
angelo350z's Avatar
angelo350z
Wow, those are extremely cheap.
Old Jun 7, 2010 | 11:51 AM
  #366
JasonZ-YA's Avatar
JasonZ-YA
Ya good prices...
good source for a 3mm but for 5mm you can get it here for cheaper:
http://www.z1motorsports.com/350_g35...oducts_id=3118
That link was taken from post 288
-J
Old Jun 8, 2010 | 08:20 PM
  #367
*ICE*'s Avatar
*ICE*
installed my 5mm spacers last week on the rear. My rear offset are 19x11 +33 and tires are 295/35/19. Everything was good for the first few days. Then this week, I feel the steering wheel wobbly and vibrate little/mild at speed above 70mph. Had a friend drove behind me and told me that the back wheels are wobbling when rolling. Driver side rear wobble more than passenger size.
Took the car to a safe place and re-check/torque down the lug nuts on the rear. 4 lug nuts on driver rear are LOOSE!!!! not loose all the way but loose enough where I have to turn almost 1/2 clockwise on my torque wrench to torque it down. Passenger size had 3 loose nuts.
1 day later, 2 lugs are loose but not too loose. Only lost about 1/8 of a turn.
My original torque specs right after I installed those 5mm spacers are 87 ft/lb. Afterward, I torque it down to 90 ft/lb.
Anyone experience similar problems? I might consider go to Pepboys and get some extended stud and swap it out the OEM one tomorrow.
Old Jun 9, 2010 | 03:39 AM
  #368
JasonZ-YA's Avatar
JasonZ-YA
Can you post pics of these spacers?? were they cast aluminum 'universal' spacers, were they machined? hubcentric??
pics plz??
-J
Old Jun 9, 2010 | 06:15 AM
  #369
*ICE*'s Avatar
*ICE*
pics plz??
-J
My spacers were the Ichiba v1 5mm hub centric type sold by many vendors here.
Old Jun 9, 2010 | 06:26 AM
  #370
JasonZ-YA's Avatar
JasonZ-YA
link? are they cnc machined units? if so, it sounds like a torque problem...
studs aren't stripped? lug nuts not cracked? probably an isolated incident or have it continued to happen...
try marking your studs and ensuring they arent spinning on the knurl after some mileage...
-J
Old Jun 9, 2010 | 07:29 AM
  #371
*ICE*'s Avatar
*ICE*
-J
http://www.b2autodesigns.com/product...roducts_id=320
Old Jun 9, 2010 | 07:34 AM
  #372
JasonZ-YA's Avatar
JasonZ-YA
humm, ya i would figure it to be a torque issue...
-J
Old Jun 9, 2010 | 07:45 AM
  #373
*ICE*'s Avatar
*ICE*
-J
I thought so too. I will keep monitor the torque at 90 ft/lb for a week and report back if there is still issue of the nuts loosing. Do i have to tighten down the nuts while the rear wheels in free space, ie jack up the rear and torque it down that way or can I just torque it while the car on the ground?
The thought of the nuts coming off and my wheels fall off while driving on highway is haunting me daily lol
Old Jun 11, 2010 | 07:52 AM
  #374
o2sys's Avatar
o2sys
Arggg my wheel spacers are stuck again, can i torch them to losen them up?
I think there is rust build up on the hub, i had a tough time last time when I was replacing rotors, now they wont even budge with a chisel!
I think applying anti-seize or something to the hub ring should be part of the DIY info, any ideas how to remove them more efficiently?
Old Jun 11, 2010 | 09:03 AM
  #375
*ICE*'s Avatar
*ICE*
what spacer size you got?
Old Jun 11, 2010 | 10:04 AM
  #376
JasonZ-YA's Avatar
JasonZ-YA
I use anti-seize spread all over the back of my spacer and the oem hub lip prior to installing them..
-J
Old Jun 11, 2010 | 11:49 AM
  #377
o2sys's Avatar
o2sys
25MM rear and 20MM front
Old Jun 11, 2010 | 06:19 PM
  #378
o2sys's Avatar
o2sys
OMG i spent the last 4 hours trying to remove this damn spacer.
I was able to remove 3 out of 4, can seem to get the rear driver side off, wont budge...
any suggestions?
Old Jun 11, 2010 | 07:19 PM
  #379
vispre's Avatar
vispre
i get a flathead (the thinnest u can find, usually a pocket clip flathead is best), then lightly wedge it between the spacer and the rotor hat using a hammer against the handle, then pry it up maybe 1-2mm, and repeat all around evenly until it has separated.
for me, i did 2 locations and it seperated fine.
Old Jun 11, 2010 | 08:07 PM
  #380
NoQuestionZ's Avatar
NoQuestionZ
Subscribble!!
