View Full Version : Wheels & Tires
- DPE Wheels.. Whatcha think?
- SOme Dick Stole all 4 of my blue SF Challenge Valve Stem Caps
- Question for Bronze Nismo LMGT4 owners
- Tire Pressure Sensor
- Vote: Which Wheels Do You Prefer
- just got my 19" Nismo's!
- Tire width vs HP loss
- i have low tire pressure warning light stays on
- Carbon / Magnesium wheels...
- Centercaps for RHS3
- tire help
- wheel rechrome?
- MT drag radials vs Nitto drag radials
- Where is Luke@DTD?
- smallest rim size for the Z (winter)
- MT ET Streets don't come in 18"...what's the next best thing?
- 305 tires on 19x10.5 are ok?
- finally got my wheels
- Rim/Tire
- offsets
- What's the point of going 19' 9.5&10.5 against 8.5&9.5?
- will i rub with my new tires? help me
- Wheel wieght
- offset for veilside v3 wide
- SSR Prof s1 and Work meister s1
- gloss black chrome lipped sf-challenge
- Work S1 19" offset?
- te37 or ce28n time attack on a PPW
- 20x10 Axis Mods - what offset for 350Z???
- Storing Tires/wheels
- question on offsets
- Dumb tire pressure question... :(
- noob allignment question
- spacer
- Wheel lugs for my ZR
- Shopping wheels
- Yes, the dreaded VDC question again!
- is this a good price for used rims???
- Another "Will this rub" thread...sorry.
- Center Caps??
- Think Spacers are needed?
- Confused on tire sizing
- what do you think about these wheels?
- Tire Leak Around Bead
- Bronze Wheel Thread!!
- ANOTHER PROB!!! Funny Sounds?
- Rh J8
- Wrong tires size?
- Tick, ping, what's that noise?
- Tire Size??
- Wheels Problem (is spacer make car vibrating?)
- How crazy is this offset? "BALLER" RIMS
- CR Kai +12 offset?
- More VOLK Goodies!
- Press Release: VOLK Racing RE30
- Perelli Sotozero snow tires
- My Z Rattles after 60mph? New Wheels?
- stretch look?
- I cured the dreaded rear axle tramp!!!
- Help on Bolt Pattern
- Need help! lost wheel lock key and brakes need to be changed
- Can't "wheel" just get along...
- Stock offset?
- Rear offset?
- TPS Need to Resync with Aftermarket Rims?
- BFG KDW tires in the rear, Toyo T1R in the front...anyone have this setup?
- Stoptech 13' Fr BBK with Axis Hiro 19' +20 offset?
- 350zZ silver on CE Time attacks pics?
- Any Z's out there w/ these wheels? (burnt titanium)
- will 6.5 Backspacing on a 15x10 wheel fit?
- Dunlop M3 winters, mileage?
- HRE 542r / maya RT5 for a Z? (Pic Request)
- From "crappy" Bridgestones to Toyo T1-R's
- Yokomaha ADVAN sport tire: best street tire for the Z?
- How much do Aftermarket wheels weight Thread:
- Running 2 Different Tires Bad/Good?
- 15x10 drag wheels with acorn style Lug Nuts
- Inexpensive Wheels Where would you draw the line?
- Need help with wheels guys...first post
- 255/285 vs. 265/295
- Urgent help pls - winter rim installation
- tire pressure sensors
- Diff between 04 track rays and 06 oem
- RIM question
- Where to find aftermarket wheel locks?
- 20" rear wheels and 19" front wheels
- lip exchange
- dropped on JIC's and work
- Fixing bent volk wheel
- Tire size question, inform the uninformed
- Check out these 20"
- Michelin Pilot PS2 305s
- will this fit the EVO
- RAYS manufacturing process *VID*
- MyTire PSI gauge is reading like 33-39 but the tires look fine!!
- Anybody have 18" Volk GTV, SF Winning, or SF Challenges?
- Volk GTS, which pad? High, mid, low?
- FINALLY, Got my WHEELS On!!! **PICS**
- any problems with different thickness tires?
- Don't know much about wheels need advice on these from ebay!
