View Full Version : Maintenance & Repair
- Brake pedal problem
- rear spoiler weight
- Vibration
- Break clunk
- heater doesn't work now,
- hard vibration when engine braking
- 350z zex problem.. please help
- what to do...crappy repair
- Cleared headlight PROBLEM!!
- Redline Transmission Fluid
- Help with Airbag light ans seat airbags
- Cabin Filter?
- Jacking up car...do I actually need the special blocks?
- HELP need instructions for Airbag resistor hookup
- something's wrong with my car!!
- I need my codes cleared from my ECU !
- Racing Stripe And Nissan Racing Decal?
- CAr has become unstable
- Vibrating mirror
- changing rear brake pads; lack service manual
- B.S at the dealer sat
- Has anyone had speaker problems?
- changing fluids and other maintenance questions
- rearbumper nailed at 90+ Now what??
- Clicking Noise
- Anyone try Pops-A-Dent
- Ping noise in second with clutch in over speed bump
- Imediate tech support needed
- need help!
- might have used wrong oil? plz help
- Does your Z ping on acceleration?
- Mad rattle sound after installing Topspeed exhaust! help!
- What to watch out for, Buying Z
- WTF, Nissan manual transmission fluid, $12 a quart?
- parking lights are out, need help or where are ALL the fuseboxes?
- alternative fluids
- how to fix a dent on the bumper
- prepurchased small dent on rear bumper
- What to do to get transmission replaced?
- Transmission Grinding Noise
- Oil Pressure Sending Unit
- When I lift off the gas, a big whining sound can be heard
- drivers side door plastics vibrate with oem stereo
- Gear whine?
- installed kinetix test pips, but...
- what size are these fasteners?
- Help needed...state inspection sticker removal
- Brake Light Stays on
- quick, need size of manual tranny for 03 350z
- after installing nismo...
- Dashboard rattle! Please help!
- Car broken into. Looking for pricing for parts to repair.
- size of hex bolt for Manual Transmission
- smashedd the rear bumper
- Is the paint galvanized or treated to prevent RUST?
- What Diff Oil To Use?
- weird squeeking noise...HELP PLZ
- CD player shut off during hard braking
- Weird engine sound!
- Rough, but not always. Need some help.
- rearview mirror rattle
- Someone check this deal for oil
- Rattle up front on passenger side
- oil consumption
- need help with oil burn on the exhaust
- Changing stock air filter
- Electronics Problems
- replacement front rim
- Trunk Dented by a falling palm tree branch
- Car will not start/please help!
- check engine light!!
- Rattling from shift knob no idea!!!
- Maintanance Schedual
- HELP! Airbag sign and Tire Pressure Sensor
- Volk Wheel Damage
- Has anyone really eliminated feathering?
- dor noise
- 15K quiet miles after alignment and new tires
- dameged front bumper
- Rust on brake rotors?
- 'Clunk' over curbs
- G35 coupe tranny issue
- 1st Oil Change
- Weird guage cluster problem..
- shifter vibration...
- Heater blows cold when at idle..
- Anyone else get a CLUNKING from the steering rack?
- brake pad wear
- So I rotated my tires the other day...
- Squeeky OEM Brembos
- Engine cut out while doing 70mph on the hw!
- Rock hit HELP
- Tranny problem, i really need your help.... please
- Will aftermarket brake pads void warrenty?
- update on my milage
- About to get a 03 Z. What are common probs?
- RE040 Slow Leak
- vin sticker ?
- Buzzing
- TPS question
