- fluids...
- no more euro castrol synthetic
- strange noise please help
- How in the hell do I make the High Pitched warning squeal stop!!
- Couple '03 Z questions
- Window supposed to be like this?
- could gaskets...
- A few problems. :(
- help on removal valve cover
- rear brake caliper bleeder nipple size
- Stupid problem...a screw that holds the back license plate in...
- Wtf Nissan Retardship/Stealership???
- Aftermarket bumper, space just below headlight?
- need help removing plastic on hatch
- Fan running without the car being on (then the parking lights)
- Damn to many rock chips
- Transmission was replaced, do i need to change the oil?
- throttle body..
- new favorite mod
- weird noise from the power steering any ideas???
- anyone else have this problem?
- Tire FEATHERING breach of warranty lawsuit field
- Problem with Z.Engine is switching off
- help! service engine soon light
- Rough 2nd to 3rd gear shift
- My car won't shift to 4th gear over 3k RPM....
- loud squeeeking!!
- what is the shutter valve
- diy axle clicking
- Window streaking
- 6th gear syncro broke?
- 06 z stuck in third gear
- Stripped Threading
- Coolant level low...how to top off correctly?
- lemon law
- Heater Control Retrofit
- Tire feathering
- Trunk issues
- Complete List of Engine Error Codes ...
- Nissan won't install Factory Nissan Products
- Ball joint noise?
- another "my car won't start" thread
- Has anyone replaced valve cover gaskets?...oil leak
- passager window???
- name that grease
- Check Engine Light + VDC OFF + SLIP
- Maintenance and saved $$$
- My passneger window is hanging up
- Key stuck in the ignition
- Would you jack up your car if your driveway had about a 20% incline?
- Flush radiator and coolant change at 30K
- d.side window noise
- Z won't start right
- Ecu
- 2 Codes Thrown, Assistance Needed
- A/C auto function problem
- Side Mirror Window Seal Question
- Weird chime/ring sound...not grinding
- clicking sound ?
- chassis lubrication..experiences?
- tranny, differntial, axle.. ??? what exactly is gone ???
- 07 grease streaks on window
- parked on a hill
- low profile jack recomendations
- Problems for the 2003 350Z's
- Do I need to take the pass. fender off to replace my windshield wiper fluid line?
- Strange sound near redline
- 2003 Recalls on my Z? Could this be what's wrong w/ my Z?
- Getting New Tranny in 350z....
- Vehicle Speed Sensor Location
- Working under the Z is a !$#%@!#$
- car starts but cut back off
- SHRTFT12 and SHRTFT22
- stranded because vdc and slip light are on and cant go over 30 mph
- A Lot of Noises
- Lots of Noises
- service engine soon?!?!
- Plugging front license plate holes
- Creatures in my hatch brake light assembly
- Need Help With Clutch
- Problems with my driver side wheel
- Do these readings look normal?
- Comprehensive stock parts website?
- CHain Noise?!?!
- putting the Z on all fours
- Fuel tank problems
- CEL light on gas tank
- p0171 code on a stock 06
- haven't driven (or started) my G35 in 6 months.. suggestions for maintenance?
- Anyone having clutch problems with an 06??
- Service Engine Soon Light
- help with bad door ding and dented sides... pics inside
- A/C Compressor Won't Turn On!?
- bleeding brakes shouldn't have to pUMp em Up
- Window Keeps Getting Stuck
- Please Help with electrical problem!!!
- Z died crossing a busy road!
- tire feathering rotate / swap front tires / mount and dismount from rim / shift belts
- 30K Service at 37K
- Build Thread: 2004 Theft Recovery Touring
