- service engine soon
- Clunk when braking.
- Lug bolt came off. Fix?
- stupid factory alarm...
- 04 350z issues/problems, how to fix? covered under warranty?
- Is this the right TRANNY part number to get?
- Burned over 2.5 quarts of oil in 3k miles!!
- Coming out of hibernation - Change the oil??
- $50 bucks to the 1st to answer this POA question-wiring color codeon fuse box conectr
- Car Won't Start!
- Recall.....
- does this sound right?
- OMG Improper Repair
- Car dying-alternator maybe?
- Extended Warranty
- Vibration at 75+
- Scared Sh!tless Pt 2
- 2 post lift recommendation
- Potential help for those that don't have working interior lights
- HELP!!! Car won't start properly!!!
- Scared Sh!tless
- safety question...
- Washer Bottle problem
- Low tire pressure light wont go off!!!
- HELP!!! Car trouble!!
- Could it be frame damage?
- Tire feathering
- evap canister...HELP!!
- Is this covered
- Passenger Window sticking?
- Help! Something wrong with my z..
- Tire pressure light comming on with out sensors in wheels.
- G Coupe FI A/T Sft prblm
- 15K maintenance
- clutch? tranny? or nothing to worry about?
- Clutch/Flywheel Install problems - crank sensor?
- Clutch pedal feeling more stiff than before.
- combo of SES light codes
- Is drilling really required to fix a small dent?
- Brake Bleed Question for OEM Brembo
- Squeak/Creaking coming from center console
- So I'm driving along today and the shifter slips out of the gate...
- Knocking noise
- A new one…
- new rattle
- Quick Question
- Potential damage ?
- that rattle that everyone is talking about..
- Nissan Dealership Trying to Get Me?
- Any Tire Feathering Problems with 2005?
- passen window prob
- Trying to self-diagnose squeaky problem
- weird noises?
- Leaking!!! AHHH
- tranny question
- Question about window motor :)
- oil psi gauge help
- fast knocking noise !!
- Drive Belt - When to Replace?
- P0463 - Fuel Level Sesnor A Circuit High Input
- My window wouldnt roll down
- P0455 - Evap Leak (LRG) w/ Evap Relocation
- 2007 350z Power Window Problem
- Service Engine Soon Light is on! :(
- Should I do some maintenance??
- 05 350z strut problem
- FYI: "Reverse light wire" grounding
- THE HAUNTED Window Motor :)
- need help on p1122 & p2135 codes
- weird engine problem
- My front tire got slashed
- Water pump
- changing tranny fluid - how often?
- I Think my battery died, need some help ASAP
- PepBoys Coupons—$5 off 30 & $10 off 50
- New Member quick ? "2200rpm Miss?"
- Rear Fender Dent!
- Humming at low rev
- Fuel Cuts?
- Engine problem?
- Tranny Problem on 06 MT
- Tranny
- power steering whine?
- Paint Question
- question about banlance and rotation?
- 03 Z - Error codes p0300 and p0021
- Rear Hatch Adjustment
- Oil pressure problem
- clutch problem
- Problem Starting the Engine
- AAAAAAHHHHH!!!! leaking oil ..
- WEIRD!! Z NOT WORKING? Key fob?
- Damn! Over Filled Oil!
- help with rust dots on top of 350z
- Naples Nissan Tranny Issues 6mt
- Tranny leak.. Inside tranny, not rear main
- Window Motorrrr:)
- Engine cooling fan always on with AC ?
- clunk and woing noise
- ECU malfuncion?
