- re vs bm short shifters!
- Why is my dealership so weak?
- Parts catalog / servie manual help
- Undorthodox Flywheel
- Unorthodox Flywheel.....
- Pictures of 5Zigen Engine Torque Dampner (FINALLY!)
- Grounding Kit Color on DB Z ??
- **help Service Soon Light On****
- New transmission
- apexi world sport II
- AEBS Stroker Kit 11.5 : 1 / 101.5mm, engine size 4269.35cc
- 3.91 rear gear. Anyone here running one??
- need help changing plugs
- Check this
- Adding Hp Without Voiding The Warranty
- To those with JWT Cams
- Clicking when in neutral
- RE shifter vs stock
- transmission strength?
- Any problems with unorthodox pulley set?
- does anyone know?
- Rev Limiter.....
- Best Bang for the Buck mods
- happy happy happy!!!
- How much Boost can I run with:
- R/T cat question?
- Question: When does the 350z start running 'lean'
- Dont get ripped off thinking you are getting pistons... True but sad story...
- boost gauge question
- Are the shifter gates too close in the Z?
- fuse?
- whats your opinion power E or Greddy
- HiPerCoat Extreme
- B&M short shifter installed.
- Exedy Hyper Carbon Clutch Package with Flywheel
- Update: Engine Oil Cooler Kit
- Is the Tilton flywheel/clutch combo to much?
- ASP Pulleys! New Release!
- Tommy kaira individual throttle bodies?
- dyno shop in palm beach county?
- 1st upgrades
- Vortech or Stillen
- scortching SS
- Anyone self install Cams yet??
- NISMO GROUNDING KIT = ExpoZed
- New nismO parts?
- What oil is everyone running?
- NISMO clutch and flywheel question
- wrong section n/t
- Hp Hp Hp
- Missing Tranny Harness Bracket Question
- anyone dyno with these exact mods??
- Self Install TT?
- What is a High Stall TC?
- How to read the A/F ratio on the dyno sheet?
- $6000 To Spend, What Should I Do To The Z?
- Cool air?
- Cams
- Video FI G35 Coupe at Sears Point
- JIC question
- CF Cooling Plate (Radiator Plate)
- Timing retard
- Just drove Jeff's car!!! Damn! is an understatement
- clutch throw
- Clutch Noise
- Light Clutch That Would Fit A Jun?
- PE Twin Turbo KIT?
- Low Inertia Flywheel= Reliable or not
- New Stillen airbox for 350z
- Crawford Strut Bar
- ECU problems??????
- PC680MJT Install?
- Stock Block, Cast Iron Sleeves?
- VK45DE in the Z
- Grounding Kits
- Oil Temp.
- Good torque converter
- Turbocharger vs. Supercharger
- Anyone Try or thinking of Racelogic TC system?
- BPU hp estimates
- calling all so cal's twin turbo 350's
- Best Bang for the buck mods for an Automatic
- Anyone else using a Futomo Oil Valve?
- Nismo Spec 1 & Spec 2 Cams
- Vq4.0
- suspension & clutch question???? HELP!!!
- Lightweight Seats
- hks vpc
- Phantom Grip LSD,.... would you run one on your Z?
- RPS vs. ATS????
- MTF drain plug type and size???
- I Feel Like A Riceboi, Yo
- Which To Buy First: Vortech Kit Or Stroker Kit?
- HELP! HKS Circle Earth Install
- clutch release?
- hey guys they decided to swap the trannny and give me something special
- Oil pan spacer kit
- Another new stand alone: check it out
- B&M Short Shifter next mod?
- Diff & Tranny Fluid, Need advise please.
