- Torgue Converter
- VB upgrade
- differential question
- How to clean the Throttle Body...
- Just FYI; It's important to have the ECU mounted properly!
- UR crank pulley belt problem - Part#
- Dyno graph for 06 stock Z!!!!
- super afcII memory
- How many miles can the VQ35DE go without needing a rebuild?
- My Z track will not let me turn on VDC
- Pulley Question
- A New Addition to the Forged Team
- Accidently reved redline while rolling
- Valve ping on 06
- 06 Nissan oil problems
- loud gears
- Clutch line
- Replaced built engine with used stock one...warranty question
- Gas Octane Level Usage
- Will a Turbo System Make Give my Z better Gas Mileage?
- ( at ) trans install
- Just ordered a few parts
- Time to dyno?
- Rear Axle Clicking
- New Valve Body
- upgraded axles anybody?
- Oil consumption, worries, etc.
- HKS Twin DLI install instructions?
- ATS and 3.9 Final Drive
- Clutch & Flywheels...Its All Greek To Me!?!
- Clutch question...
- ACT prolite and CM FX300 install
- Burning oil??
- trans probs
- gaining more power of a stock Z
- Tranny fluid
- Z uses same piston rings as used in 2.5 engine?
- Those that know about this trans and clutch come in.
- $2,000 for now... what to spend it on?
- 2006 o2 sensors
- Clutch won't pop out, Can't Drive
- 06 Motor swap ?
- ECU Error Codes -- very helpful
- Poll for all 06's owners
- The new VQ35HR
- Trans. exchange{009}.
- Car won't start sometimes.
- If anyone hasn't changed the differential fluid yet...
- Installed Braille Battery. Bose Stereo not working...
- Using copper NGK plugs to resolve pinging.
- Price of auto tranny fluid change at dealership
- leakdown test, how long should that take?
- SPEC CLUTCH problem
- Question on engine compatibility
- What to do after cracking a head?!
- need some opinions on my 5AT
- What should I to start with before FI?
- Startup
- Two engine dampers in Z
- Power steering fluid
- Question about rev-up
- Removing diff pumpkin
- Diff. cooler?
- Fuel pump question
- Supra 2jz-gte swap into 350z??????
- Pheonix 5AT Racing Valve Body for RE5R05A
- New owner, need advise with service issue
- Dont you just love it when people help you out!
- cams advance timing?
- Cams and nitrous. please look
- says I had a Cylinder Misfire...HELP
- Block with bent rod...still good for building?
- ATS Carbon LSD
- Forged Pistons And Rods
- Performance Motorsport's Pro Series Heads Now Available
- My Progress with Cipher (charts included)
- 2006 350z redline?
- New tranny.... Bogging?!?!
- Just dynoed my car
- How much does the pumpkin weigh?
- Got Dyno'd Today....
- I might have killed the car.....
- Dealership actually doing Right Thing...
- Car shudders/chatter when engaging in 1st
- 6spd swap?
- Weird clutch problem you might not have heard of.. HELP!
- Anyone with a 3.9 gears and cams?
- time for a new clutch
- Honking sound while shifting @ high revs ??
- building a n/a monster
- Dampners and reducing harmonics...
- Stillen Stage4 Plus Exedy Clutch & Flywheel Install Pics
- Grinding Noise
- ppl with AUTO Q?
- Greddy Informeter?
- fastest place to get a jwt clutch
- do clutches come with warrantee?
- Feeler for GB
- clutch suggestions?
- rought idle
