- Lasting effects of burning the clutch disc
- How many miles do you consider as breaking in your car
- is the 02-03 maxima vq35de engine short block as same 350z's shortblock??
- LSD makes a big difference?
- Traveling
- koyo radiator
- friends+turbo
- RevUp Oil Consumption TSB and discussion
- disadvantages from a smaller pulley
- vehicle speed from front wheel or rear wheel?
- ACT clutch
- Bad driver?
- 350z Clutch.
- Clutchmasters FX100
- Cooling issues
- oil change at the dealer
- throttle body wire daigram
- Driveshaft question?
- vq35 to ls7r
- 3.9fd gear oil
- Need Help Please !!!!!!!!!!!!!!!!1
- help
- Clutch slipping
- our are hoses metric too?
- Droppin in the V8
- Silly question re: built motors
- Tranny Ticking.
- Can you over spin the alternator?
- Another monster roadster by AAM
- HELP!!! Need fitting!
- Oil Drain Valve anyone?
- Engine swap
- Which Short Shifter is the Best?
- Whats going on - second throw out bearing
- I'm new, quick questions
- Defi VSD Concept Install Info
- Rev-up engine vs. non Rev-up
- Some help
- Oil use and oil type?
- Might be a stupid question
- Thanks to MRC
- Return fuel and EMS
- Anyone running JWT cams with revup heads?
- Polished caps
- Some pics needed!!!!!
- Some pics needed
- standard backlash for ring & pinion?
- I know this is gonna sound stupid, but . . .
- Ticking sound from the engine?
- VQ longblock dimensions?
- Eletrical burn type smell coming from the engine
- Engine Dampener Installed!! pics!
- Just bought a quaife atb....
- Intercooler question
- stillen engine damper came apart
- What mds besides Turbo?
- how to change park plugs?
- Pop clutch and exhaust pops?
- 1 week and I got the "bug"
- Fuel pump fuse
- Power Enterprise 3.8L Stroker Kit?
- The Ferrea valvetrain?
- Anyone ever tried Tufoil (tough oil)?
- OEM Oil Filter Thread Size?
- Engine head.
- Getting ready to "build" my motor...
- My new KN pop up is lame???
- Fuel Pressure issues, Experts please
- Is anyone elses gearbox notchy?
- New clutch and light flywheel problems
- Those of you that know about ARC Catch Can...
- need advice now! Please Help
- want to rebuild shortblock!
- Transmission whine
- AM Upgrades that are proven?
- Oil Catch Can Question
- best bang for the buck...
- Idea for another gauge
- People with Aftermarket LSDs:
- JWT clutch/flywheel or 3.9 gears: best bang for the buck?
- High flow cats/ test pipes or lightened crank pulley
- Transmission issue? need some insight!
- Possible Clutch Issue
- '06 Pumpkin into '03 G Coupe swap: IT FITS!!!
- 8.8 CR No Boost Review + Help
- Transmission running excessively hot-almost burning!!
- Burning Smell
- Tomei's Technical Trax Advance 2way LSD
- Oil cooler installed APS TT
- Engine problems...possible solutions/advice
- looking for rear end parts
- what is the best LSD out there?
- Cosworth Cams
- 06 noise when accelerating
- Base model With no LSD
- A/C question.
- anyone seen dynos after AEBS install?
- Sometimes Hard to Get in Gear
- Possible Problem With UR Pulley
- Aftermarket LSD and VDC
