- UR Pulley + Lightweight Flywheel = No Engine Braking
- UR Pulley Vs Nismo Flywheel
- NISMO LSD vs. Stock Viscous LSD
- Next mod
- Nismo R-Tune Rip
- My new mod arrived today!!!!
- Improving mileage ( how? )
- 5zigen
- Spark plugs
- Anybody See That Nismo Article?
- Those of you that have 19" and 20" wheels (Moderator's please don't move to wheels!!)
- U/R Crank Pulley INSTALLED: Review/Writeup Inside !
- Chicago area catback installer
- stupid question for you
- Dremeled my Crawford
- ecu flash!!!!!
- When is the GReddy Evo coming?
- Torque Brace- Who would want one?
- gear to dyno in!
- tightening belts
- **Is it safe to "Techosquare" ??**
- torque damper
- UR pulleys and TQ damper
- pulleys = good
- RSR vs Pro 1 vs Invidia
- anyone seen this yet??? (ARC catch tank:) )
- Where is the best place to buy the UR Crank Pulley??
- dynorun yesterday
- Car wants to DIE when idling!! Whats going on ?
- Need nitrous installation shop in PA/NJ area
- Technosquare ECU removes speed limiter?
- Throttle body allignment
- How 2 install Nismo ground kit?
- First Oil Change
- Nismo LSD GB?
- Nismo LSD GB
- Independant throttle bodies
- Stillen Oil Cooler!!!
- Do I Need Tranny Swap?!?!?
- air guide/filler panel
- Transmission Problem Fixed yet?
- UR Crank Pulley = Squeal at Start-up??
- Building a reliable FI VQ
- review of Tommykaira car - ITB sound clip
- DREAMWORKES SC Update
- Per Cylinder Fuel Maps?
- Write up on LSD install?
- Bouncing off the rev limiter
- Good Borla TD gains.. Dropped my ETs..
- Borla vs. Stillen
- axle back exhuast...
- Dyno Ready
- Request for RS*R ExMag GTII Video/Sound Clip
- If you installed an aftermarket Torque Converter for your A5T please post HERE!
- Anyone have a 350 EVO throttle body?
- Need stock belt part #
- does JWT have best heat shield design???
- 350Z TT or new Vette Z06?
- Anyone have a short shifter?
- Any Supercharger kits for RHD vehicles?
- What type of 1/4 mile times should I see with the Procharger??
- RSR GTII or Tanabe Racing Medalion
- Just got it! Where do I start?????
- Horsepower
- Transmission Questions
- Installed Borla TD.. I did before and afters with my G-Timer
- Manumatic lazy shifting
- Crank Pulley
- throttle position sensor
- how much would I expect to be paying to install a short shifter?
- VIDEOS of my Setup (Borla, R/T, JWT)
- Bounced off the rev limiter. Consequences?
- Help ! Nj Z Owners.
- Question: Burn out mod/brake fuse mod
- Transmition Vibration?
- resetting the ecu
- Clutch
- z-xtreme grounding kit
- Will Altima (3.5L) Crank Pulley Fit the 350Z
- NA Power
- Got a Quick Question about..If my tranmission is messed up or will be...?
- Anything new on the ECU front?
- Cams Or Fi????
- JWT Flywheel Revving?
- Thanks Jeff/Jason @ Performance
- Nismo Flywheel... No Noise At All!!!
- Service Engine light on at 16k
- Flowmaster 80
- my stillen supercharger install
- Getting a rattling noise when cranking
- mods in a 5at z
- Proper A/F ratio?
- Am I running lean ?
- Infos on the 350evo final drive???
- anyone have pics
- Wicked small Video of me leaving my friends house at night
- Anyone with a JUN Lightweight Flywheel burn their clutch?
- Jobs that pay for boost?
- need some direction...
- Dyno results
