- How to install...
- ECU question
- Hydra Nemesis anyone?
- houston unichip tuner
- Recommendations for HP gains and cooling upgrades
- UTEC air temp compensation spreadsheet
- Idle Speed Increase
- OBD II Sony PSP
- power gains from tuning on n/a
- need help with rough idle/running lean
- Utec On Map
- UTEC load points
- greddy e-manage ultimate or u-tech
- RC 650cc and Fuel pressure?
- Dyno results with Osris, and exhaust cams unplugged on a revup.
- Utec install cost?
- How to subtract Timing with Utec?
- Engine Stress
- Scaling Big injectors with UTEC
- G35 ECU Terminal for Engine speed?
- G35 On the Dyno Solution to the Rev Limiter at 5300-5500 RPM Florida
- UTEC base map for Vortech, 3.12, 440 injectors?
- Knock sensor installation
- Anyone have to replace their alternator?
- My first UTEC log...any suggestions?
- How to install utec on g35
- Tuning Help
- New Tune (Sharif) w/ Evott Exhaust and UR pulleys
- Any interest in "Staged" level REFlashes?
- Cant boost in 1st gear! Heres my logs:
- UTEC: Why does it say stock mode?!
- Can you flash the UTEC via the USB port on the UTEC?
- Anyone have a UTECtiming map for an NA Z
- HKS EVC question....
- UTEC + aftermarket wideband o2 sensor
- How to connect AEM Uego to computer.
- CEL-Throttle position sensor code w/ UTEC??
- Tuner UTEC problem
- A/F & UTEC Problem
- Mac tuning software
- From SS Box to Utec...
- Where can I get an R4 software from?
- MPS_UTECLogger V3.0
- VERY URGENT Emanage Ultimate Problem (2-step)
- ECU Noob In need of advise!
- R4 software
- apexi "neo" sufficient for bolt-on tuning? is u-tec overkill?
- Any One Using UTEC CLBC (Close Loop Boost Control)
- A/F tuning ?
- ecu flash
- what to buy
- UTEC installation question: Molex?
- need help with utec
- Utec + 440cc injectors, help with map
- A quick question on different rear gears
- Help installing TXS Tuner kit
- Finally, a good dyno session, and a tune.
- Will an EMS help ME?
- AEM Fuel / Ignition Controller (F/IC)
- Engine management for HR motors??
- How much does a tune normally cost?
- Strange UTEC problem. Map Sensor?
- Turbo'd without a Tuner?
- Having problems with the utec
- knock sensor type and info
- Autometer nexus oil temp help
- UTEC update problems, any advice?
- Tuning in Minnesota
- Patch harness question. Very early ecu versions
- Recommendation for another reflash
- Unichip plus 10 RON Octane Booster - timing?
- unichip tuners in tx
- logging on a pda
- Osiris vs UTEC, my experince.
- Does the UTEC come with the Map sensor?
- Utec Decisions and questions....
- Emanage help simple question
- To all you tuning gods
- was my computer already tuned?????
- Tuning?
- UTEC Tuners
- what should i do ??
- Having trouble uploading map to UTEC from PC
- Cobb Access Port... Any updates??
- Greddy 440cc UTEC Base Map?
- Need help wit A/F issue
- need help w/ unichip
- Knock Logs
- AEM piggyback
- greddy Emanagement/UTEC/Apexi A/F controller bahhh help me
- UTECH or AAM ECU Reflash?
- expected dyno numbers....
- Logging AFR and RPMs with Innovate or other?
- Afr 17.5 +
- Soft Rev Limit on UTEC
- Tuner for the MAF???????
- Air Temp & Humidity: Effects on performance
- Some issues with my UTEC
- UTEC tune problems
- New Dyno Run!!! and question??
